BX-24 Cooling w/ hood open
   / BX-24 Cooling w/ hood open #1
okgarcia
I have been using my backhoe to dig a seemingly endless curtain drain trench and thought it may be a good idea to operate my machine with the hood open to vent the heat. The fan still cools the radiator, but I don't really know if the air still gets to the front of the engine compartment to cool the exhaust system and whatever else is up front which may need cooling. Does the exhaust system need to be cooled anyway? Any reason to close the hood except for the little bit of extra noise? I wear headphones all the time.
   / BX-24 Cooling w/ hood open #2
I see no reason to open it?
   / BX-24 Cooling w/ hood open #3
is the temp gauge getting up near the top?
i agree, i've never run w/ hood open and don't see real reason. i usually run the hoe at about 2800 rpm. i don't seem to get things going much faster at higher rpms and make more mistakes.
for me, when running BH for extended periods, i, as the operator, am the only thing that gets too hot. the HST fan blows air over the hot hydraulics and back and it rises right up into the operator platform. i rigged up a small, 12 volt fan i clip onto the ROPS and plug into the 12 v power plug. helps a lot on those hot summer, endless, BH digs.
amp
   / BX-24 Cooling w/ hood open #4
Temp gauge is what I watch, although when I'm done for the day and after I've shut the engine off, I then open the hood for a bit.....Nothing to base that on, it's just what I do.
Don
   / BX-24 Cooling w/ hood open #5
Thanks for that. I'll be using that solution now as well.
I too run at about 2800 RPM when operating the backhoe, and have never seen the temperature gauge be anywhere but right in the middle where it always is. But, I still see no reason not to open the hood. If your gauge is running hot, I'd look into the cause of that though, and not just use the open hood as a Band-Aidョ.
   / BX-24 Cooling w/ hood open #6
Bx's use reverse air flow drawing the fresh air from the operators area.
To have the hood open is kind of defeating the system as it can then draw air from anywhere out the top.
In the long run it might weaken the fan blades from an un-normal flex and cause failure.
   / BX-24 Cooling w/ hood open #7
Art is right - Opening the hood will stop the normal airflow and could make things worse. It would have dust collect more in the engine area which I am sure you don't want. Leaving the hood closed would ensure the intended proper airflow through the front grill over battery then radiator then engine and out. If you notice too high of temps, you might want to check your prescreen filter and then clear out the debris from the radaitor.
   / BX-24 Cooling w/ hood open #8
If you want opinions I've got one too. Sounds like you have a good idea and it won't do any harm. More ventilation will help the cooling.
   / BX-24 Cooling w/ hood open #9
I would think you get better cooling with the hood closed as the air gets directed over the exhaust/block and out the front.
   / BX-24 Cooling w/ hood open #10
i'm going to fully disagree with that statement.
the tractor and cooling system are designed to fully and efficiently function with no forward movement, and the hood clsoed. opening the hood interupts the way air is moved around under the hood, and it will NOT cool properly.
if you ever see one of those portable tow-behind industrial air compressors, they specifically on them to operate with the doors closed, as it is designed to cool that way, even though it seems as opening the doors will help it. look at large stationary generators; totally enclosed and fucnction well.
   / BX-24 Cooling w/ hood open #11
Without Kubota engineers to confirm they actually designed this machine as tightly as you think it remains... what you believe is your opinion not a fact.
   / BX-24 Cooling w/ hood open #12
i work at a bobcat/kubota/kobelco/wirtgen/sweepster dealership, and have been to kubota school, put on by kubota, at kubota facilities, and have heard this from kubota training personel. i have been through kubota's electrical, cooling, hydrostat, and hydraulics courses. it is a fact, not an opinion.
oh, and think about this: how many tractors do you see with the hood open while they are sitting there powering stationary equipment like generators, water pumps, log splitters, etc?? i've never seen any, not one. some people think into things way too much.
   / BX-24 Cooling w/ hood open #13
Cooling in any device/machine is designed as a system and there are many parts to this system. I would bet money that the engine cover is part of this system. If you take a part of this system out, it will most likely not function as designed.
A very specific case of this exisits in the computer/server industry. Some people feel that to help their computer deal with heat better, they remove the case. In most cases, this causes the opposite as the case is part of the airflow management of the unit. Many of todays servers will not even boot with any part of the case removed as cooling system is engineered to require all parts and without the case, airflow is disrupted to the point where the server would most likley overheat and fail in a matter of minutes.
One other thing to consider is that you may be doing more damage than good as well with running your tractor with the engine cover open. Most of the hoses and plastic components that are under the hood, most likley are not designed to be in direct sunlignt for long periods of time. Plastics require UV inhibitors if they are in direct sunlight and there are considerations with longevity when adding UV Stabilizers to plastics. I would also bet money that most of the items under the hood do not take this into consideration.
Cheers,
   / BX-24 Cooling w/ hood open #14
The question could be objectively evaluated with an infrared camera. But I just ain't that curious. I *want* air flowing through the entire engine compartment.
After hard mowing I idle down for 5 minutes, then open the hood after shut down. Lets heat out and reminds me to check the oil next time I start up.
If BX's have a heat management issue, it is the hydraulics. No oil cooler. The hydro consistently runs 90-100 degrees (F) above ambient. Attached image is after trenching (BH) on a 90 degree day.
   / BX-24 Cooling w/ hood open #15
All I can say is that I would not want to run my BX-24 without the airflow being forced around the engine/exhaust system for any length of time. More to keep the plastic cowling that surrounds the lower portion of the engine compartment cool. Without the hood closed air is not being forced around the engine and forced out away from the lower shield. Heat radiation could have an effect on the plastics. It's your BX and do what you want with it but I will side on the cautious side and run it as designed.
   / BX-24 Cooling w/ hood open #16
The actual cooling affect aside, have you ever seen how bad the hood vibrates while opened and running. I'd be afraid that it would shake all the hardware loose and break something. I also pop my hood after I get done on a hot day. It's amazing how much heat pours off the engine when shut off.
   / BX-24 Cooling w/ hood open #19
Disipation of heat in any manner is a good thing with regards to precautionary measures in the prevention of overheating.
   / BX-24 Cooling w/ hood open #20
I feel the same way about how this machine (while I love it for what it can do and how well it performs most tasks) just does not seem designed to run at a 100% duty cycle. I have had the "heat" problem both when BH'ing for long periods of time in the heat as well as using the FEL for a couple of hours straight.
I agree with the thought that an external cooling coil (see the Surplus link) placed on the return line to the tank would go a long way to helping things out.
https://www.surpluscenter.com/item.asp?UID=2009071918380752&item=9-5357&catname=hydraulic
For about $120 bucks (for the unit, hoses, some 12v computer fans and some couplers), I plan on building one of these at some point to help out this problem. I am not sure how much it will help, but I have burned myself leaning against a ram by accident after heavy use.
This verbiage is from MaintenanceWorld.com: Solving hydraulic system overheating problems - Insider Secrets To Hydraulics
Hydraulic fluid temperature - how hot is 'too hot'?
Hydraulic fluid temperatures above 180 ½°F (82 ½°C) damage most seal compounds and accelerate degradation of the oil. While the operation of any hydraulic system at temperatures above 180 ½°F should be avoided, fluid temperature is too high when viscosity falls below the optimum value for the hydraulic system's components. This can occur well below 180 ½°F, depending on the fluid's viscosity grade.
Based on the thermal image and my own personal experience, I would bet that the fluid is getting hotter than what is optimal during long use periods. As far as the concern for this thread, I feel the engine is sufficiently cooled by its liquid cooled radiator, the hydraulics on the other hand are a completely different issue.
2025 RB66 66in Rock Bucket Skid Steer Attachment (A59228)
2025 RB66 66in...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
WHIRLPOOL REFRIGERATOR/FREEZER W/ICE MAKER (A60432)
WHIRLPOOL...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2017 CATERPILLAR 305.5E2CR EXCAVATOR (A60429)
2017 CATERPILLAR...
