BX1860 54" deck and Gator blades
   / BX1860 54" deck and Gator blades #1
mow4fun
Flemington, NJ
Well, I got a set of Gator blades today and mounted on my 54" Fine Cut deck, the number is 96-748. I have the mulch kit installed as well and while at greased the deck and topped the gear oil.
What a great cut, the original Kubota mulch blades did a good job but the Gator blades are exceptional. Some pics below.
   / BX1860 54" deck and Gator blades #2
I agree! I have a 60" MMM and bought a set of Gator blades to try. They are so good I sharpen them and put them right back on and have the Kubota blades as just as back-up.
   / BX1860 54" deck and Gator blades #3
Interesting. I also just purchased a set of Gator blades for my regular cut 54" deck. They were listed as a direct replacement for K5617-34330 Oregon #96-748. But the holes were too small (23/32 = 0.72) for my RCK54-23BX deck which has 7/8" shafts. It cost me $25 to have a machine shop enlarge the holes as my 7/8" HSS drill wouldn't touch the hardened steel.
But ... the results in cutting are beautiful I agree.
So it seems the fine cut has a smaller diameter quill shaft.
Yes, that was one thing I was worried about and was very happy when it was perfect fit.
I also noticed a different humm from the deck with these blades, did any of you notice that too?
   / BX1860 54" deck and Gator blades #5
hmmm. maybe but I wasn't listening for it. Just watching the gorgeous results. One thing though - I normally mow @ 3-1/4 and I set it down to 3" with the Gators.
   / BX1860 54" deck and Gator blades #6
Looks good! I put Gator's on my BX2200 54" deck 3 years ago. I side discharge currently, but I do have the mulching baffles in the garage. The original Kubota mulching blades didn't near as good a job as these Gators though. The Gators have a ton more lift to them.
Maybe I will put my baffles on and see how it compares to the old original mulching blades then. The reason I took the baffles out, was that my deck always left a little narrow line of clippings along the left side of the deck. It annoyed me, so I just took the baffles off.
   / BX1860 54" deck and Gator blades #7
but what do the gator blades do that Kubota blades do not? Just asking since I get a better cut from a std deck with std blades...Help me out here...
   / BX1860 54" deck and Gator blades #8
hate to be the stick in the mud responder, but i ran gators and toro atomics on my toro z master 100, zero turn mower. . . was told specifically, that the mulch blades within a closed off mulch chamber were supposed to be lower lift, and within the chamber they would cut and recut the grass clippings and put the back into the turf.
i read on the gator website, that they are to be run, open chamber/side discharge- no restrictions for best cut . . . whose to say? i guess your experience will be your guide.
i queried my first kubota salesman about blade tip speed and kubota decks, and he basically said the cut wouldn't be as good . . . regardless i wanted to move to a year-round machine (bx2360) and did . . . live and learn . . . am glad your experience has been a good one . . . if i go to gators . . . it will be without the baffles and chambers . . .
regards, D902 BX PILOT
This is directly from Gator's website:
Is the Gator Mulcher right for my mower?
On standard mowers, the Gator Mulcher works best on multi-blade decks, particularly when mowing into the discharge. Mulching adapter kits are not required. For single blade applications we recommend installing a mulching kit for best results, but you will see significant mulching action even without an adapter. Gator Mulcher blades will enhance the performance of any mulching mower, single or multi-blade.
   / BX1860 54" deck and Gator blades #10
Hmm....Who knew!!?? Since I tend to be lazy about these things.....I guess I'll not bother to dig the baffles out then!! :)
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
2002 Freightliner FL70 Elgin Street Sweeper Truck (A51692)
2002 Freightliner...
Polaris Ranger SxS Doors with Bolts (A51573)
Polaris Ranger SxS...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
