Hey guys, I've heard of two tractors so far with the "steering problem" you're all describing. One was a
B2710, and one was a
B2910 with the "updated filter set up". Yes, all the new tractors are coming through with the new filter set up. BUT THAT IS NOT THE FIX..... There is no service bulletin to upgrade to the new filter set up as I've seen mention of in previous posts. Trying different fluids is not going to work. Had a customer bring his
B2710 in with the problem. I took the machine out for a test run, after approx. 45 minutes I got the machine to perform the described problem. Drive the tractor in a straight line for about 40 yards and make a sharp turn (as if you're turning for your next mowing pass)
The outside air temp at the time was approx 75 degrees. That's when it shows up (feels like steering power goes away for a few seconds then comes back). Noticed it only happens in left turns (Hmmm..what side is the mower discharge chute?) Also, at an idle, tried the quick turn to the left and geuss what? same problem, but only to the left. Soooo.. now I,m thinking the port for left turns must be further away from the source of flow than the right port, but if the breakdown in the manual is correct- that is not correct, the left turn port is closer, so much for that idea. Bumped up relief pressure to see if that would have any effect-no change. Lowered relief pressure-no change. Now I'm thinking cavitation/starvation but what's bugging me a little is when a pump cavitates you can hear it, usually makes a barking/chirping sound. OK, let's check pump flow output. (you all do realize that that's a dual pump set up, the front section is for hyd ops and the rear section is dedicated to steering) Flow test the power steering section of the pump and my numbers come out a little low, and I do mean a little low. Under normal circumstances I would'nt have even considered it a problem, but everything else checked good. Removed and dis-assembled the pump and found some very minor scratches in the housing. Replaced the hyd pump and noticed a difference right away. Idle steering was better, tested for at least one hour, same air temp, and could not duplicate the problem. Delivered the machine back to customer and followed up with him about 2 weeks later, he stated that he too noticed an improvement in steering right away and has not been able to duplicate the problem. I'ts been at least 3 months, and I have not heard back from him (which is good news, I hope) Now before you guys go scrambling to your dealers for new hyd pumps, I'm not totally convinced that a new pump will solve this problem. Although it appears in this case to have done just that. My customer has'nt had a full mowing season to effectively check the results of this repair. I do not know the results of the
B2910 mentioned earlier (another dealer). What I'd like to know from you guys that are having problems is: Does your failure mimic the previously described symptoms, what is your model and serial number, note atmospheric conditions, throttle positions, all variables you can come up with. We sell
ALOT of these tractors and I'm very interested in this particular problem.
