Carry -All Phase one
   / Carry -All Phase one #13
That really looks nice.
Check the archives for Top 'N Tilt on a BX, there are actually quite a few who have added this feature. You can get either or both. For the carry all, only the top would be needed. If you have a box blade, using both top and tilt adds tremendous versatility.
I use my carry all when spraying. I got a 15 gal sprayer from Northern Tool that was designed to bungee strap onto an ATV and just strap it to the carry all. It plugs into the tractor electrics for power.
Old steel barbell weights make good ballast. I bought 22 50# discs (std 1" holes-not Olympic) plus a few 20#ers for $110 on Craigslist. You could build a box or weld up bars on which to stack them.
   / Carry -All Phase one #14
Air Force Chief:
I got your PM. I'll just reply here. The "archives" means all the old posts, going all the way back to the beginning. When you do a search, you're searching all the old posts; that's the same as searching the archives.
About 5 or 6 years ago, a major server change was made. Things in the archives prior to that time can be more difficult to search. If you go to this thread, then the tenth post in the thread, you'll find a list of old threads related to BX top and tilt:
http://www.tractorbynet.com/forums/kubota-owning-operating/120616-top-tilt-bx24.html
Gearmore currently makes correctly sized hydraulic cylinders for top and tilt on a BX. Many Kubota dealers have accounts with Gearmore:
Gearmore Products
Another manufacturer:
http://www.ccmachinery.com/TNT.htm
There's a third named Rankin; their prices traditionally are higher.
BTW: is that your personal car (mustang?) sitting in front of that B2?
Air Force Chief:
Gearmore Products
Tractor Hydraulic toplinks, Top-N-Tilt, Side link cylinders
Thanks for the info. Appreciate you taking the time.
As for the pic, yes it -was- my car. I sold it after I found my current one...:D
   / Carry -All Phase one #17
So I went to two TSC stores today to find a County line Carry all. I brought it home stripped all the stickers and sanded it down. No that I come in the house I noticed mine is completely different than your? Mine seems allot more heavy duty. Is mine an old style? I don't think it is as they said they just came off the truck today :confused:
Who makes them is variable based on where you live. TSC buys from many different places. I've seen at least three different styles marked "County Line"
   / Carry -All Phase one #19
Seems like there is no rime or reason to the way they are drilled? I don't think they put much thought into it. I have been playing around with different 2 x lumber to see how I'm gonna make it work. To get holes kinda in the middle of the boards and to give some over hang.
   / Carry -All Phase one #20
Do you have any pictures on your tractor yet? Just trying to decide how wide I want to go. Thanks
Roose Hog Cart (A50515)
Roose Hog Cart...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
David Bradley Manure Spreader (A50515)
David Bradley...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
