BX grass catcher boot question
   / BX grass catcher boot question #1
bellweather
Western MA
Kubota BX22
I bought a used grass catcher for my BX22 with 54" MMM and I am not sure if I have the boot attached properly (see pic). It has a mounting bracket that is completely different than what is shown in the manual. Although the boot itself fits my mower deck, I'm not sure if it's mounted properly? 3 issues of concern...
1. There is a bolt at the top which does not align with a hole on the deflector flange.
2. The brack has an extension on the front end which appears to have no purpose.
3. The mower deflector is digging into the shoot.
   / BX grass catcher boot question #2
What model grass catcher do you have gck60-bx or gck60-23bx The later is the newer verions. The bracket looks like the one I have. I believe it fit a rck54-23bx I think you have a rck54-22bx that may be why it looks different.
Could it be that Kubota did not update the manual to show the newer unit? Or maybe the manual I have is for the earlier version?
How does your boot mount to the deck?
My grass catcher mounts using the 3-point hitch arms and top link, which I understand is the earlier unit. I believe the newer ones mount to the frame.
My mower is the RCK54-22BX.
Thanks!
   / BX grass catcher boot question #4
My cather is frame mounted. I cant tell you how the boot mounts as it wont arrive for a few more days. My bagger came with a 54" boot kit and I need the 60" boot kit. I will know in about 1 week.
If you haven't already returned the 54" boot kit, can you take a picture of it and post it? What does it show in the manual?
Thanks!
   / BX grass catcher boot question #6
Sorry didnt get a manual. What does your manual show?? I looked at kubotabooks.com and the boot kit setup looks different than what you show. What you have looks like it fits the new style deck. I will look and see how the hardware mounts when I get home. The hardware should be the same just the boot itself is different. BTW your kit looks like the one for my deck and bagger.
Like I said in my original post, the manual shows a different boot mounting bracket than the one I have.
Thanks!
   / BX grass catcher boot question #8
I have the 60" BX mower deck. My boot shape is slightly different than yours. You have more of a taper from the leading edge back to the shoot. The deflector width near the hinge point is about 13 1/2" on mine, the hole is about 9" from the leading edge. Holes on the deflector plate and mounting bracket align on my deck. This keeps the boot located properly to fit over the deck chute exit. Your bolt #1 passes through the top of the deflector and screws into the welded nut below when you mount the slotted adapter to the deflector plate. Your item 2 keeps the front of the boot aligned in place when in the down position. The boot fits over the end of the mower exit chute when properly aligned. The end of the deflector does not touch the shoot on my machine. See the attached photo. Your hardware looks very similar to mine (about 2003 vintage). I can't remember if there was a "heavy duty" version of the boots which is perhaps what I have.
Perhaps the boot I have is for a 60" mower deck?
   / BX grass catcher boot question #10
You got me curious and I went out to the garage to check numbers. My deck is a RCK60B-22BX. On the bottom of the boot, there were 5 numbers (6 digits each) stamped into the plastic, one of which was hand "X" ed as 104270. I have a whole goods list from 2003. For my deck size there were 2 boots, BX3061 and F30624 which was the heavy duty boot. It also lists 2 additional boots, a BX3040 boot for the RCK48-15 deck and the BX3051 boot for the RCK54-22BX and RCK54-15BX decks. I don't know the difference between those last 2 decks. The standard boots were $140, while the heavy duty was $227. I bought my catcher used for $1175 and BOS did not indicate much detail other than the description and serial number of the bagger.
2018 DIAMOND C 40 FOOT GOOSENECK (A53843)
2018 DIAMOND C 40...
2018 John Deere 325G (A47477)
2018 John Deere...
Honda Pioneer 700 NR (A53424)
Honda Pioneer 700...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2014 DRAGON 500 BBL FRAC TANK (A53843)
2014 DRAGON 500...
