3-Point Hitch Long 48" Brush Hog on BX25
   / Long 48" Brush Hog on BX25 #11
My B2320 w. 48" LP cutter. I take it places you can hardly see into. Go slow & be safe.
   / Long 48" Brush Hog on BX25 #13
Here is a picture of the 48" LandPride on my BX2660:
   / Long 48" Brush Hog on BX25 #15
I am wondering if a Kubota BX25 w/42" brush hog would do well in 5"-6" grass and weeds. Thinking of buying a 42" brush hog but not if a 17HP diesel won't pull it at a reasonable pace without stalling. Never run a brush hog before, I could use some advice. Thanks!
In general terms 5 pto horse for each foot of "hog" You should be good with a 42, and if you were just cutting grass, you should be OK with a 48.
   / Long 48" Brush Hog on BX25 #16
I "think" you can turn the 3PT adjusting knob, on my BX25
it is like close to my right heel as I sit in the seat, I think
you can tighten it all the ay up and lock the 3 point at
any height, I guess it there is no harm no foul for the chains?
   / Long 48" Brush Hog on BX25 #17
That knob controls how fast the 3ph goes down and it locks it. If you have the 3PH half down and lock it and pick it up it will be locked all the way up. You mainly lock it for run on a road so you won't bump the lever and drop a implement in the road.
   / Long 48" Brush Hog on BX25 #18
What are the chains for on the lift arm pins, height adjustment?
The chains are in tension when you lower the 3PH for mowing, and therefore set the front cutting height of the mower. There is no load on the 3PH during mowing, except for pulling.
I'm not sure about the 3PH lock function, I use the chains because the dealer provided them with the mower and instructed me on how to use them. My dealer has been excellent at advising me on attachments and their operation, so I am staying with this set-up.
Here is another photo of the chain arrangement. They hook to hard points on the tractor frame:
   / Long 48" Brush Hog on BX25 #19
That it what I thought they were for since the BX doesn't have a position control on the 3PH.
   / Long 48" Brush Hog on BX25 #20
The BX25 Manual talks about those tabs for chaining up the 3ph.
I do not exactly remeber where I saw it but 2 weekends ago I was
reading and I remember seeing it. If I remember right it says the
tabs are for chaining up the 3ph so it will not fall...
This hookup is all good in my book. Learn sumthin' new every day!
2016 MACK CXU613 SLEEPER TRUCK (A52576)
2016 MACK CXU613...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
2014 Freightliner M2 106 Medium Duty Truck with Tool Bed, VIN # 1FVACWDT0EHFS2811 (A51572)
2014 Freightliner...
