I have to replace my busted HST fan, either via the expensive Kubota-approved technique of moving the engine and shaft apart or a cheaper homebrew solution such as:
- cut the new fan in one place, twist to get it over the shaft. Bolt / glue / zip-tie into place.
- cut twice into halves. Bolt / glue / zip-tie the pieces into place.
- fabricate new sheet metal blades and screw to old hub
It would be helpful to know how these alternatives have held up over time.
If you've taken one of these approaches, how long has it survived and which solution did you implement?
