Cutis Cab on B2920 First Impressions
   / Cutis Cab on B2920 First Impressions #1
jambx
Gold Member
Southern CT
B2920 TLB, ZD21-60P, 1949 US Baird Beaver
I wanted to give some feedback on my Curtis Cab install.
I finally unearthed a Curtis Cab off Craigslist - it only took 5 years as I have been looking since 2009 for a used one in like new condition.
Initial take-a-ways;
Quality - I actually was skeptical on the build quality of these cabs until I received mine and took it down to the last screw, cleaned everything up and put it back together and installed on the tractor. Quality is very very good and now understand they are priced accordingly. I have the soft doors and soft rear window. I have zero experience with the hard door cab from Curtis but can say that the soft one work very well. I do know a lot of guys keep their cab on year around but mine will come off in the summer as I enjoy an open cab and working in the woods quite a lot requires a much lower profile than the cab. Although I just don稚 see the reason to have hard glass for the doors a nice touch on the B2920 model is that there is a hard rear side glass which works great and really gives the unit a quality to it. They did not go cheap on this design. The wiper motor works great however the front lights are very weak and was shocked to see how much Curtis demands for these I will replace with some trapezoidal ones in the future. I purchased some off Amazon in the past for a fraction of what Curtis gets and they work much better.
Noise - wow - yeah its loud. So loud I do use ear muffs - I could not do without and use the muffs with a Radio and iPhone hook up. Stream music while I play...er.... plow. I can not tell you how happy I am. Yes it is LOUD at 2X maybe 3X however with the ear muffs its a non issue and brings tractoring to a whole other level. I just do not understand however how guys can operate a Radio through cab speakers in one of these cabs since I would think you would have to crank up the radio to overcome the interior noise...I did see a post where the member Waxman soundproofed his cab and from all indications it does a very good job for what appears to be a little outlay. I will go this route next year.
Impression - the door opening is huge and climbing in/out is very very easy. The door handle mechanism is top quality and locks firmly in place when shut. The front and side visibility is excellent - the front window is huge and curved backward providing visibility upward as well as straight out. The side doors have large clear openings and as I stated there is a solid side glass behind the doors. The rear window plastic is acceptable but not outstanding. Of course a solid glass or plastic like they use on the doors would be better than what comes as standard as it kind of takes on a clear plastic wrinkled look - but I think they make it so the user can roll the rear window up.
Heater my cab did not come with one and have operated in single digits. While I do wear a carhart Bib and ONLY a sweatshirt - I find I am never NEVER cold - in fact I almost at the point of too hot. Why someone would shell out an extra $400+ for a heater is beyond me. I hear guys blowing snow in shorts and T shirts - sounds like fun - until you have to get out of the cab to shovel, change blade angle etc. Its winter - dress for it. I just dont see the point.
Installation very straightforward and took me about 2 hours to install. Basically there are four brackets that bolt right onto ROPS. The side frame has a floor plate that bolts to the floor however I decided to hold off and was surprised how solid it was without the need to drill the floor. I also was shocked to see how air tight it is I have heard about fogging issues but I have yet to experience any. All the parts that touch the tractor use rubber to protect any scuffing. I am a one of those nuts and was hoping there would not be any marring of the paint and I can now say this is a non issue the rubber does a great job protecting the paint. Unfortunately I had to rework my lights that were on brackets fasten to the ROPS since they interfered with the back of the Cab roof. I decided to use some channel and u-bolts which I was now able to pull both the fronts and rears inward under the ROPS which gave me the clearance I needed. You will notice the U-bolts are upside down the washers and nuts actually rubbed against the back of the cab so for your guys looking to put a Curtis Cab on a B take note.
Removal - Since I will be taking this off in the summer I will plan to make a rig to be able to hoist it off in one piece and have prepared all the electrical connections for the lights and wiper with quick disconnects.
Conclusion for those that are considering a aftermarket cab I would highly recommend one (Curtis or Sims etc). I did look and research some other manufactures at considerably less cost however there is a HUGE difference in quality. I also agree that Kubota should consider offering a factory cab for their smaller platforms I think it would sell quite well. Since I require the ability to take the cab off for the summer and a factory cab will not give me that capability. So the aftermarket Curtis Cab hits that sweet spot?.,,,then again?....for me the Craigslist score makes it even sweeter :)
Below are some pics of the fit and finish. Sadly I do not have many pics of the cab apart as I was rushed to get it all together since we were being pummeled with snow the very weekend the cab was delivered and wanted to get it installed. Curtis has a web site which you can download the installation manual so it will give you a idea of what is involved but it was one of the more fun projects.
   / Cutis Cab on B2920 First Impressions #2
I like the view you have with it. Nice job.
   / Cutis Cab on B2920 First Impressions #3
A VERY NICE set up....let it snow let it snow. :D
   / Cutis Cab on B2920 First Impressions #4
I know now what I have to do....thanks for posting.
   / Cutis Cab on B2920 First Impressions #5
Thank's. I was considering one of those. But like you I didn't want a cab in the summer. So it's not a big issue to take it off?
I was also wondering about fogging while snowblowing. Thanks for addressing that.
Paystar - as i said its a piece of cake to pull off - if you have a strong buddy you would be able to lift it right off in one piece after unbolting the four ROPS brackets. It is a home run from my perspective. Re-install should take less than a hour.
As for fogging - I keep reading others saying theirs fogs up and they have to add a fan etc - not me - I think one of the reasons I have not experienced it yet is the fact the I do not have the skirt that fits under the seat so I have a lot of air moving around but I can not stress enough that I am never cold (only wear a sweatshirt). I think the main benefit with the cab is not being exposed to the wind.
Bottom line - I should have done this years ago - I love being out plowing when the wind is blowing and snow is falling - just a kick :cool2:.
   / Cutis Cab on B2920 First Impressions #8
Thanks again for the info. My dealer likes the Curtis Cab too. It's the one they recommended.
I would want the rear glass though as I have the rear blower and want clear visibilty.
   / Cutis Cab on B2920 First Impressions #9
I have another question for you. I was looking at the Curtis brochure my dealer gave me and it only shows the soft cab for the B series. But it is available with the solid rear glass panel I would want.
I'm wondering.....how do you like the doors on yours? They are vinyl? Are the side windows soft? How is the visibility through them? No distortion?
Just wondering if I really need a hard cab if they are available for the B, or if that soft cab is all you need.
Only downside is where I am in Canada I was quoted $4200 for the soft side and $5800 for a hard cab!! A lot more than what I see people on this site paying for them in the U.S.
Paystar,
I do know the hard glass side doors are a option for the B but to be honest I do not see the benefit for the additional $$$ for the hard doors let alone the added weight (as you know the doors can pop right off for those times you do not want total enclosure). The soft ones are clear thick vinyl and there is ZERO distortion - you actually think you are looking through glass they are that flat (unlike the rear window which is thin and gets wrinkled easily BUT I have no issue looking through it at my rear blade and I do plow mostly in reverse) - if I was going to put money into any option it would be the REAR window glass over the vinyl.
Crazy money for sure but again for me these cabs offer the best of both worlds (unlike a factory cab) I can enjoy a open platform in the summer and toasty in the winter. For me I plan to have this B for a long time and the cab makes 1/3 the year much more enjoyable - if I ever do trade up I can EASILY get my money back for the Cab. Here in the US these puppies used still sell for a premium and there are a line of folks buying.
At the end of the day I am 100% positive you will not regret the cab (soft or hard doors) - but if you want my vote (especially at a $1600 premium) Soft Doors all the way.
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
2005 INTERNATIONAL DURASTAR 4300 (INOPERABLE) (A55745)
2005 INTERNATIONAL...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A55745)
2017 FORD F250...
2018 TURNKEY INDUSTRIES  DATA VAN (A55745)
2018 TURNKEY...
