y
How much does a BX-25D weigh?
   / How much does a BX-25D weigh? #1
valkyrie9901
Adrian, Michigan
Kubota BX-25D
Was wondering the weight of a BX-25D as my trailer has a capacity of 2340 lbs.
How do you rotate the pic? It was right when I uploaded it.........JB.
   / How much does a BX-25D weigh? #4
I am of no help. I have noticed several other attachments that were rotated in the last day or so. It may be a forum-wide problem. You could try reloading the photo.
Steve
   / How much does a BX-25D weigh? #5
   / How much does a BX-25D weigh? #6
Pretty sure that's the weight of the tractor less the FEL and BH...Guessing the whole thing goes around 3k give or take.
EDIT: The answer from Messicks in another thread:
Tractor - 1600
backhoe - 700
loader - 400
= approx 2700 lbs.
That makes sense.
Steve
   / How much does a BX-25D weigh? #7
I live right beside the local sand and gravel yard, so I weigh pretty much anything. So with me sitting on my bx 25d it weighs right at 3000 pounds. So that puts the tractor + loader and backhoe and loaded tires at 2800 once you subtract my body weight. These scales are very accurate. They are calibrated every few months.
   / How much does a BX-25D weigh? #8
that makes sense, as the messicks numbers quoted above may be dry (w/o fluids)
   / How much does a BX-25D weigh? #10
Loaded tires might be in the equation too
   / How much does a BX-25D weigh? #11
Google it...
2023 MORBARK WOOD HOG 6400XT HORIZONTAL GRINDER (A60429)
2023 MORBARK WOOD...
1990 International F-4900 Tri Axle Dump Truck (A59230)
1990 International...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2020 Ford F-250 Ext. Cab Service Truck (A59230)
2020 Ford F-250...
2002 Ford Thunderbird Convertible (A59231)
2002 Ford...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
