Upsized Hydraulic Clyinders for Loaders
   / Upsized Hydraulic Clyinders for Loaders #11
One thing that I think any serious piece of hydraulic equipment needs is an accumulator. I design my hydraulic fixtures with these, and have one on the L39.
The stick response has a 1/2 second delay, that I am very used to. However when you hit the chuck hole, the shock is quite a bit less.
Do you pressurize your accumulator with nitrogen? I believe that is what we used on our Mack Aerialscope ladder truck years ago.
   / Upsized Hydraulic Clyinders for Loaders #13
Is NH Hydraulics building them?
I've Posted to that thread actually.
Lauren may have his pressures set low, as mine were from the factory. If he has increased his lift capacity 50%, that is over 4000Lbs!. See the attached loader curve Lift graphs from my manual.
The OEM stock lift capacity IS quite a bit more at mid lift than full height. Plus 2 ton lift ability is too much for the L39/L45. Even Lauren's foamed tires and cab will not keep weight on rears.
I'd be completely happy with another 15-20% extra lift. Even with that I'll be grabbing a boulder with the BH thumb for safety.
The Curl is the L39 weak point, designed that way to protect the front Axle. As long as I'm careful, I think I'll get away with boosting the Curl 35-35%.
I have not approached them yet.
They Repaired the boom cylinder on my Komatsu. . I'll ask them to quote once I get it all spec'd out.
Sure Did, 2200 Psi Initial fill, Hope it is still there! Air filled accumulators are dangerous, especially large ones that leak a and then diesel (BOOM!)
   / Upsized Hydraulic Clyinders for Loaders #17
Very, very, proud ($$$) of their work in my experience. Just FYI. Heard nothing bad about quality though.
   / Upsized Hydraulic Clyinders for Loaders #19
Your accumulator sounds like the accusatory that is the basis of the Kubota Ride System (KRS) on large Ag tractors. It really softens the bumps when gathering up large round bales. Increasing curl force that loads your axle - I'm trying to understand the load condition. My L5740 is extremely weak in curl when having the bucket curled completely flown and try to push myself out of the hole in which I'm stuck. Major difference between this and the L3710 I traded in. The problem here is mechanical advantage - almost zero in straightening the bucket after its tilted completely. The Grand L front axle is weak, especially in bearings judging by the info I found when I failed the LH side bearings on mine at about 600 hours. My dealer said one customer has the system down - he pulls both fronts when one side fails and takes them to the dealer to repair because the other side is always likely to go soon. So which curl load is hard on the axle? When I curl in the bank I think I am just rotating the bucket around the rear corner do the axle is not getting extra load; however, I could get a more full bucket which would hurt it.
Re: Upsized Hydraulic Clyinders for Loaders (Attached drawings)
I believe construction full size TLB's have a system as a option Similar to the Kubota Ride System (KRS).
Regarding increasing the curl force, this can put a lot of strain on the front axle. The best way to avoid is as yon mention, go in with the bucket a little high and bury the bucket in the pile as best you can in rear wheel drive.
Then curl the bucket back, while not Lifting or driving forward aggressively.
The works thing you can do to the front axle, aside from hitting a loaded tractor with an excavator, is to be in 4Wd, bucket under a stump, etc. driving hard forward and lifting an curling at the same time. The little bevel gears in the front axle are torque aversive, along with the spindles and just about every other component, including the steering. If your doing this with the edge of the bucket you may also rack the loader.
I suspect tractors are designed with weak loaders for safety during operation, and protection against abusive use.
Me, i respect a machine that can hurt itself with a little help.
On a well designed tractor, the safety factor has to be huge to give the tractor a degree of idiot resistance. The world is growing better more advance idiots on an exponential scale, so lots of bad stuff is going to happen.
Regarding your L5740 that like the Kubota Construction TLB´s and many better designed loaders the bucket linkage has 4 pivots, vs. 2 so as to get a getter amount of dump and curl back angle. At the extremes of motion, that type of linkage has very little leverage.
But wait, there's more!
Your L5740 has a regeneration circuit on the dump cycle. During dump full pressure is applied to the extend and retract ports,. Motion occurs due to the area difference of the rod, speeding up the dump cycle.
Some loader control valves have the flow dump back to supply tank ant the beginning of the jioystick movement to dump, then go regen.
A suspect that Kubota's are 100% regen.
GrandL's crap front bearings and seals just because the are not that beefy. Knock on wood, my front axle is not leaking after +500 hours since the repair. I think there are several seal kit versions Kubota has cycled thru over times
Carefully moving heavy pallets and rocks with my pallet forks is where I want the extra curl and lift as from the photo's below, execpt in hard digging, the L39 is adequate. I try to be as gentle a front axle abuser as possible.
Attacthed are my resized cylinder drawings.
  • Max28 Lift OS 4-2-16.pdf
  • Max28 Curl OS - 4-2-16.pdf
  • L39 Lift OS -4-2-16.pdf
  • L39 Curl OS_4-2-16.pdf
2019 Komatsu PC490LC Hydraulic Excavator (A49461)
2019 Komatsu...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
Ford 641 Workmaster (A50514)
Ford 641...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
377811 (A48836)
377811 (A48836)
2012 CAT 930K (A50854)
