Power steering B8200
   / Power steering B8200 #2
I don't, but if you find a source for them let me know. I would love power steering on my B7100.
   / Power steering B8200 #3
Me two, with the fel loaded it can be quite difficult to turn my b7100, hence the evergrowing biceps /forums/images/graemlins/grin.gif
Mat
   / Power steering B8200 #4
I've looked.for my B8200. Would have to hit salvage yards.
It may be possible that the setup from a B20, B21, or B2150 might work. I have never had one side by side with mine to see.
   / Power steering B8200 #5
I looked at a B21 today. The PS is in the steering box. It would incvolve replacing the manual steering boxes on our B8200's.
   / Power steering B8200 #6
Guys: if you are lucky, you will find an old original Kubota add-on kit, like I did. It basically is a servo-valve (my term) and a double acting cylinder that fits where the original pitman arm is now. Works off the hydralic block via a pair of hoses and a check valve. It would have been a snap to install on my 8200 had there not already been a member supporting my FEL in the way. Anyway, I find it was worth the trouble, now that I have it. Works perfectly, like it should. The kit was put together by Kubota USA, partly OEM pieces and partly stock USA stuff. I had some images of it I could post, in case anyone is curious...
   / Power steering B8200 #8
Okay: here's a pic of the "servo" unit as I call it...
   / Power steering B8200 #9
and the rest of the steering kit...
   / Power steering B8200 #10
What problems did you have working around the loader supports?
I got my B8200 w/o loader. Two years later I added a Bushhog QT loader(looks like what you might have?).
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2016 John Deere 326E (A47477)
2016 John Deere...
2017 KENWORTH T880 (A53843)
2017 KENWORTH T880...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
