Rear remote on a BX22.....
   / Rear remote on a BX22..... #1
Junkman
Super Member
North East CT
2003 Kubota BX-22
I had previously posted about this and here is a link to the thread. if you would like to know what originally transpired.
Today, I finally got around to installing the Kubota rear remotes. To say the least, the instructions were poor. Mounting the valve was the easy part. Once I got the right hand tire off, it was easy to get to the oil return port. Loaded tires are not something you want to handle a lot. Getting it back on is also a pain. Getting back to the rear remote. I put the 3 hoses into a nylon protective sleeve and hooked up the return line at the valve and the JIC fitting. For those that might want to add rear remotes, the fitting is a 9/18-18 JIC adapter and the hose is approximately 38" long.
This next picture is where the JIC fitting goes....
JIC fitting installed......
This is what it looks like with the hoses going to the return and forward to the front connections.. As you can see, it is a very tight fit. I used the same nylon protective cover on the two hoses that went to the front. This turns out to be a big problem, because the only way to the front is by going on the inside of the frame. After struggling for more than an hour, I was finally able to get the hoses routed so they were snug against the frame. When I finally had everything hooked up and secure, I started the engine to try the remote valve and check for leaks. Great, no leaks and everything worked the way it was supposed to. Gave the throttle a little kick and suddenly, it sounded like the drive-line was going to fall out the bottom. Shut down the engine and crawled under to see what had happened. Apparently when I put pressure to the valve, the lines moved and the nylon covering was shredded by the plastic fan. The good news was that both the fan and the hoses themselves were not damaged. Spent about 30 minutes looking under there to see if there was a place that it could be secured to, but there isn't. I have come to the conclusion that I will have to drill two 1/4" holes in the floor pan and use a wire tie to secure it to the pan so the cooling fan doesn't take a second bite. I also realize that it might take a second set of holes to secure the top section of the hoses to the floor pan if there is any movement that I haven't accounted for as yet.
   / Rear remote on a BX22..... #5
Junkman, you sure have some nice looking carpet in your garage. How do you keep it so clean?????????????????
Ok, seriously, did you buy a Kubota kit or DIY parts?
Someday, I hope to mount one on my 2200. Someone posted very detailed info on that and I printed it off to assist me......
Best wishes,
Ron
The one problem that I see for everyone that uses the Kubota supplied kit or makes up their own kit, is this clearance. I also realize now that there is an easier way to do this on the BX22. All I would have had to do was to use shorter hoses and run them to the backhoe connection. This would have accomplished the same thing. I am now torn between removing the hoses that I have just installed and having new ones made or drilling the floor pan and gambling that the fan never goes after the nylon covering again. If I had used a smaller nylon covering, it would have worked out better, but that is what I had, so I went with it.
Here is a picture of the valve installed and plumbed. Unfortunately, I had to lower the valve because the 38" return line wasn't long enough when the valve is positioned as in this picture. The valve is now located on the "S" curve section of the ROPS, not where I had wanted it. I am not sure that it isn't going to be too close to my leg when using the backhoe.
I keep the carpet clean by only using it for pictures. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
I purchased the Kubota Kits. One kit is the valve and the other kit is the hoses and JIC adapter. If I had it to do all over again, I believe that I could do it less expensively by ordering non Kubota parts. I might still remove the long hoses and order new hoses to hook up to the hoe hydraulics. I really don't like drilling holes if there is a better way.
   / Rear remote on a BX22..... #8
I hate to ask, but what are "rear remotes" for?
I intend to use the rear remote for the adjustable 3 point hitch top link. When I have time, I am also going to add a hydraulic cylinder to my landscape rake so I don't have to get off the tractor to turn it. The second cylinder will require a second valve to be added to the existing one. This translates into more $$$...... Some people see this as a lazy mans toy, but at my age, the less that I have to climb on and off the tractor, the better it is and the more that I can get done.
Can't sleep... my mind is still thinking about these hoses. Question.... since there are only two lines to the backhoe and when you remove the backhoe, you join these two lines together, can these two lines be used to power the rear remote? The reason that I ask this question is the rear remote has a return line back to the reservoir. The backhoe doesn't. If I were to connect into the backhoe lines, would the return line in the valve "steal" the pressure that the backhoe needs to operate? I have learned that the Kubota valve is a "open center" and that the hydraulic oil is flowing through the valve at all times, or at least I believe that is the function of an open center valve. What do you hydraulic guru's say??? Will my idea to hook into the backhoe lines work without disrupting the backhoe? Thanks for your input...
Just went back to the original thread that I had started a few months ago. After reading MadReferee's post, I believe that this won't work. Guess that I will just take a Valium /forums/images/graemlins/crazy.gif and forget about this till I get the answer from someone that understands all this plumbing. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif Going to sleep now, and I hope that sometime tomorrow someone will have solved this problem for me.... I feel like Henro... not knowing if I should drill holes or not.....
2018 Dodge Grand Caravan SXT Van (A53424)
2018 Dodge Grand...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2005 Dodge Ram 4x4 Crew Cab Pickup Truck (A55852)
2005 Dodge Ram 4x4...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
2016 Chevrolet Traverse SUV (A55853)
2016 Chevrolet...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
