BX22 HST Fan and Shaft Dust Boot Replacement
   / BX22 HST Fan and Shaft Dust Boot Replacement #1
Mike_C
Gold Member
Ohio, USA
Kubota BX-22
The fan that cools that HST on the bx22 is a cheap plastic fan that is not well protected from branches that flip up under the tractor. I lost several blades off mine, so I ordered a new one (well 3 new ones to be exact). They are cheap, only $4 but it's not a 5 minute job! I tried to do it from underneath without removing the floor pan, but it just was not possible. I could not get the propeller shaft out of the way to get the fan off, so I had to remove the floor pan. First a picture of the broken fan before I replaced it:
I found that just unbolting the propeller shaft was not enough. I had to remove the flanges to get it out of the way. To do this requires inside snap ring pliars. I also replaced a broken dust boot on the shaft in the process. Warning, after you remove the inside snap ring and pull out the shaft, there are 4 ball bearings on each end that tend to fall out and roll away! Don't lose them! Attached is a detailed photo of how the shaft mates into the flanges on both the engine side and the HST side:
So as you can see you also need to remove an outside snap ring to replace the dust boot. Time from start to finish 3.5 hours. Next time will be faster; I was going slow to make sure I knew how to put it all back together. The new fan installed:
   / BX22 HST Fan and Shaft Dust Boot Replacement #4
with the pan off looks like easy access to lube any pivot points on levers and rods.
   / BX22 HST Fan and Shaft Dust Boot Replacement #5
Mike,
Nice job. Thanks for the comprehensive how to on the fan replacement. Pics were great. Your efforts are certainly appreciated.
Jeff
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2024 Scag V Ride XL Zero Turn Mower (A51573)
2024 Scag V Ride...
(APPROX 15) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 15) 2" X...
UNUSED FUTURE ELECTRIC MASSAGE CHAIR (A51248)
UNUSED FUTURE...
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
