BX 3PH Mod part numbers
   / BX 3PH Mod part numbers #1
Scrounger
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I've found a few threads on the mods to the BX 3PH using parts from the B series 3PH but I can't find the part numbers. I can't however find the part numbers and what it will cost to make the change. I think its only about $50 total but not sure what to order.
Can anyone help. Thanks.
   / BX 3PH Mod part numbers #2
Go to Tractorsmart.com, call or email, I hear they have the list on a postit somewhere close. I think the was was a bit higher, $150 or so. i believe you are talking about the sliding lift arm adjustment with the drop in bolts.
Nice mod to.
Good Luck,
Rob
   / BX 3PH Mod part numbers #3
Rob,
I looked for that page and couldn't find it. If you could post a link, I'd really appreciate it.
Tom
   / BX 3PH Mod part numbers #4
Here's a link to a thread about the change over, but on the BX, you only need two parts for each side. http://www.tractorbynet.com/forums/kubota-owning-operating/49403-b7610-3pt-stabalizer-replacement.html
In the attached pic, you need to get the parts # 160 and # 220, you will need two of each. I can look up some other posts and show you the modification that needs to be done to the part # 220 to make it hook to the lower lift arm.
Here's also a pic of the completed install, notice the end of #220 that has the single hole has a slot cut in the side to enable it to attach to the ear on the lower lift arm.
   / BX 3PH Mod part numbers #5
Here is the parts list that I used for my 3PH mod. Hope you can read the numbers. This prices are early 2003.
John
   / BX 3PH Mod part numbers #6
Scrounger
Did you find your parts yet, I didn't have the part numbers either, I printed out the pic and took it to my dealer and showed him the parts that I needed, they are for the B2910 so he looked the part #s up and ordered them. I screwed up on the # on the other post, should have been two of the # 220 and two of the # 170, I should have caught that earlier.:eek:
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
Excavator Mulching Head (A50774)
Excavator Mulching...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
2006 International 9400i (A52128)
2006 International...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51242)
2024 AGT...
UNUSED FUTURE QUICK ATTACH CURVED LOG GRABBER (A51244)
UNUSED FUTURE...
