So,,,,, Saturday, Lil would not start, jumped her off and everything was fine, Let her run at a high idle for a while. Was a concern, because that is one of the original reasons that the previous owner had her in the shop... and they FIXED it...
So Hanna went to run Lil yesterday to load mulch. One of the basic functions Lil is supposed to do.... You guessed it, Lil will not run.... So, Hanna jumps Lil and all is good. Hanna comes back for the next load.... Tries to jump Lil... Melts the clamp tooth on the jumper cable which allows the hot (Positive) jumper cable to fall down across the battery box, melting off the insulation which my wife then reaches down and grabs this red hot, shorting out, clamp..... and burns her hand......................
Needless to say, My wife cussed my Hoe a blue streak......... (think it hurt Lil's feelings as a matter of fact
) cause she would not run, so when Hanna could get no more satisfaction cussing my Hoe, she called me on the cell phone and picked up where she had left off............
You ever heard the saying, You can always tell a German, You just can't tell them much
So, my evening was spent trying to coax Lil back into cooperating, and had to re-learn some basic rules again, such as START WITH THE BASICs
Seems that in all the work the shop did on her, they never cleaned and straightened out the battery connections.
Dufus me figured I grabbed and they felt tight, they were ok, but as I was not getting consistent meter readings it had me wondering....
I think Hanna was still a little miffed after we sat out there an hour or so fooling around with Lil, when I realized I just needed to pull and clean the cables and she fired right up, charging system was all working fine..................
Just thought I would share
