Flatheadyoungin
I'm not used to the type of power diesels produce so it may just be me......
say i'm mowing thick stuff or going up a long, steep grade in high gear.....and i'm running it pretty hard, we'll say, if it does start to bog, it does seem like it has trouble recovering........
however, on ATV's, hot rods, etc....i'm used to something having way more power than needed.......example: i was climbing a hill on my 700 raptor the other day (i've done quite a bit to it) and needed to slow down for certain parts of the climb....while my buddies' smaller bore bikes would bog and then they'd have to down shift, i would just slow down and then get right back in to it, knowing that i had way more power and responsiveness than i needed.....but, then again, my 390lb atv has about 5 more hp than my tractor, so it really isn't a fair comparison
with the tractor and i'd assume this is with all of them, if it starts to bog and you step on the throttle, it's usually too late and you need to turn off the pto or press in on the clutch....i guess it's a power to weight thing, tractors use gearing not raw torque or hp...
i don't know if this answered your question or not, heck the guy that had a JD 85hp turbo cabbed tractor bogged his down too on my property.....
honestly, though, pulling that large 88" flail mower takes some guts and i'm more than happy with what it will cut....it actually shocks me at times.....usually if it starts to bog, i just decrease my ground speed or press in on the clutch and let it regain it's momentum.......
now that i've just about got all the rough stuff done to my property, i'd trade mine in, in a heartbeat for a cabbed hydro.....
if you stick with any of the big ones; kubota, new holland, JD, etc...i don't think you can go wrong....then it comes down to what you are looking for; price, features, maybe style, support, etc.....
how much of a difference in price is there? .....i'm just curious
Flathead do you have any probs with the motor being slugish sence its a non turbo?? I really like the new holland seems to have alot of great features, but the non turbo does seem to worry but then again look at one of the most popular farm tractors in history a JD 4020 they were a great tractor, but they had 2 more cylinders and 55 more hp.
lonecowboy like i said in the PM it sounds like you got another lemon. I think im going to go right for a new T2320 and make payments on it. If i buy it.
