FINALLY I got some seat time yesterday. About 2 hours of teaching myself how to grapple, plus some bush hogging.
I moved a very large (maybe 30') cedar about 150 yards and mow it is along my driveway and easy to access.
I moved the "Firewood" the loggers left me which required me first to use the root grapple as an earth mover whereby I broke down some big lumpy dirt and bark/debris piles to create a semi level space where I could manuver the tractor to 90 degrees so I could grapple the logs. I moved them all away from the area I'm clearing to a spot where I can easily run my saw and at least buck them into managable sized logs, if not firewood.
I also worked on my finesse with the grapple trying to pick up a single 2" tree without tearing up the ground too much. I did manage that.
I am struggling with these two things now.
#1 he grapple closing at the same time as I am tilting it up seems only one or the other works and the logs were slipping out.
#2 the area I am bush hogging is VERYlumpy and I hit dirt hard on the cutter, do I go out there with the bucket and just knock them out, or ???
Thanks in advance.
I'm hoping for a little seat time today also.
David
