The big reason I went after that dab of firewood is that I wanted to see how it did in the woods. Overall, I'm impressed, but there are three shortcomings of varying severity:
1. It's a miserable Esso Bee to steer, and it gets worse when you lock the front differential. It REALLY needs power steering in the woods.
2. Ground clearance is extremely limited. If you can't go around small obstacles, you can alleviate that by taking advantage of the articulation by running one side or the other over things that you'd hang up on if you straddled them.
3. At full turn, the inside front tire very nearly hits the footboards. If you're not paying attention to where your feet are, you could mess up a foot pretty badly.
On the plus side, the 9 gears and locking differential pretty much allow you to go anywhere you have clearance, and that 20 HP single cylinder diesel lugged that loaded trailer out of there no problem and up about a 30% grade without bumping the throttle above a decent idle. In the first of 9 gears, you'd need a calendar to time it over the quarter mile, and in top gear it'll do about 15MPH down the road.
