cartod
Took time out to smooth out the new driveway before the next snow storm.
I am not sure how well schedule 40 PVC pipe would feed into that but the long roll type stuff might work good till I hit a big rock which I usually have plenty off, but luckily didn't hit any when doing this project. My biggest headache was when digging into the existing water pipe to make the tie in. I hit the pipe with the back hoe and pulled some more joint loose that required more digging and more breaking of joints till I finally had to dig up the entire works at an existing faucet. Then after getting all the broken joints fixed and holding my 100 PSI water pressure, I hit the darned faucet bracket with the FEL when backfilling the big hole and broke it again, requiring me to dig it all up again and start all over (it broke 3 joints ) Finally after 2 days and some hand shoveling this time when I got close to the pipes, I got it all put back together after several trips to a local hardware store for parts. What started out with $150 worth of plastic pipe/fitting and a $46 freeze proof faucet turned into another $80 worth of pipe and fitting. My original measurement of needed pipe was short so I added in some additional pipe and then more tees, more couplings, a couple of unions, a couple of 1" valves and a repair to my sprinkler anti siphon valve. I knew I had the contractor put in a set of valves to isolate my shop water from my house but when I was looking for them, I couldn't find a valve box for them. I bought a valve and union so I could install one and when using my shovel to dig into the line to install it, I luckily hit on the valve box that had been buried under about 3" of dirt. I don't know when that happened but it is now uncovered and luck for me that I found it on the first day of work so I could then turn on the main water valve so I could get water to the house. It ended up taking me 2 more days to get all the leaks fixed. Due to the cold weather, it took several hours for the glue to set whereas in summer, you could turn the water back on in just a few minutes. After pressurizing too quickly one time after an hour set time and having the whole shebang blow out, I started gluing up and left it set over night and that worked.That one is from New Zealand. Here is similar from Agri-Supply.
3 Point Subsoiler-Subsoiler Attachment | Agri Supply #73410
3 Point Pipelayer-Pipe Layer Attachment | Agri Supply #73622
Will handle up to 2" pipe.
Ok, not exactly tractor related... But today's seat time involved a new toy.. I mean more equipment for hard "work"
All tarped in case I hit snow. Drove down to Ohio to get my new to me scag (30 hours on her).
Don't mind the bags of empties and kids toys in the background
A lot of work but I had a couple of positives from the whole experience. I found my missing shut off valves, ended up with a lot of spare plastic fittings for any future repairs and did get my new faucet in so we don't need to pull 300 feet of hose (now only need 100 feet) to get to the garden. I could have put the faucet in the garden but would have been constantly having to watch out for hitting it when plowing the garden, so I put it by a power pole that is the perfect protection and I used the power pole to mount the faucet and my hose roll up rack where it is completely out of the way.
Looks like you will have a nice house once it is completed.
View is nice when the leaves are off, still a few more months til we can get moved in.And a great view too!
