Unable to adjust 3 pt top link
   / Unable to adjust 3 pt top link #1
Socratic
New Hampshire
Kubota BX2230
I recently picked up a used BX2230 so I can clear my driveway (getting too old to horse the walk behind snowblower up a 300+ ft driveway). I purchased a Frontier from the local JD dealer (best price for the RAD - Blizzard blower that seems to be made by them for many manufacturers). When hooking up the 3 point hitch, the lower arms just barely clear the pins on the blower mount point - had to slide one on first to make room for the other. Once on, they seem to be okay - though it does take a bit to get them on.
When hooking up the top link of the 3 point hitch, I shortened the link all the way and the blower still doesn't sit on the ground - the resting foot is about a half inch off the ground. The blower has a very slight tilt. Is this because I have the lower links spread as far as they can go and are therefore too short causing the blower to be closer to the tractor? Should I invert the attachment pins so that they are on the inside of the mount instead of the outside? That might give me more room for the to pin adjustment?
The manual says the the mounting pins should be on the outside - but maybe this is a manual for mounting on a JD and not a Kubota?? I need to be sure I have the blower properly mounted before I shorten the driveshaft (next challenge). Any advice appreciated. Thanks. Jim
   / Unable to adjust 3 pt top link #2
I'd say if its possible to unbolt the lower pins and turn them to the inside, do so. Its certainly going to bring the bottom of the blower in closer to the tractor when the lower arms are spread as far as they can go. If this doesn't cure your toplink issue, then my first thought is to send you to Tractor Supply to get a shorter toplink. If they don't have a short one, i'd buy a cheap one and shorten it if needed before I cut the stock toplink.
Yes, I am leaning toward that solution - just wasn't sure if the extra couple of inches made any difference on the stability of the blower.
   / Unable to adjust 3 pt top link #4
Hello,
The top link with BX's is oft times problematic. Although I am not sure a shorter top link is in order, but perhaps a longer one. It may be holding it off the ground, and a longer top link may be needed to allow it go to the ground. A photo would help show us which is which.
Do you have a sense that the lower arms are able to descend to their normal position? Do they look higher than their lowest point? In other words, is the too short/too long top link preventing the lower arms from going down all the way?
Yes, you certainly can reverse the pins. Sometimes this is necessary, but I have doubts about this making a whole lot of difference in ascent and descent. Usually reversing the pins is what I have to do if the implement is 27" wide. The BX's prefer a 20" width of Cat 0. Of course, the BX uses Cat 1 pins though. If you got it on, struggle or not, it likely is already 20 or 21 inches. The manual likely is true and not recommending reversal of the pins. Some photos would help us a lot to see what you are up against.
Best Wishes
   / Unable to adjust 3 pt top link #5
Also, you might check the pto shaft to see if it still has room to slide and shorten as you let the implement down. Sometimes the pto shaft needs to be shortened but be careful because if that is the case and you shorten it too much it can come completely out of its outer sleeve when raised up.
   / Unable to adjust 3 pt top link #6
Before cutting 3rd arm or moving pins, unhook the PTO shaft and see if the blower will then go down. Drop the 3 PH down to lowest postion and make sure that your draft control is not holding it up, and then try to move the PTO shaft back like you are going to unhook it, If you can move it back then it isnt binding, if not, then raise the 3 PH and see if you can move it then. You may have to pull the shaft apart and cut a few inches off of the male part of the drive shaft. As mentioned dont cut more than you need. About 1 inch shorter than the required length at the lowest point should be sufficient.
One question, when you drop it down, which direction is the pressure on the 3 rd arm, from the point closest to the tractor or further from the tractor. Extending the 3rd arm will make the implement set lower to the ground. You should check the drive shaft lenght regardless if you figure out how to get the blower to go lower. It can bend the shaft if it gets in a bind, then you have major problems.
   / Unable to adjust 3 pt top link #7
I just reread your first post and you did say that you shortened the top link as much as it would go. That is your problem. You have to LENGTHEN the top link to lower the implement. You have it as high up as it can go with the top link as short as it will go.
Again, check the drive shaft length before using the implement to make sure it isnt binding, after you lengthen the top link so it will touch the ground. The blower should set fairly level
   / Unable to adjust 3 pt top link #8
When they changed the BX series to a "full cat 1" hitch they raised the mounting points of the lower arms, or so it seems anyway. My B2620 is the same way. It gives a higher lifting ability, but the arms just barely go low enough for some implements. My chipper is that way, and to be honest, I hadn't thought about moving the pins to the inside. On some terrain, it will barely sit on the ground. Some BX owners with the same chipper have mounted the chipper on 4x4"s, but obviously that won't work so well with a snowblower! :D
   / Unable to adjust 3 pt top link #9
what about about adding some sort of quick hitch to extend the arms, make hooking up easier and then not having to cut the PTO shaft?
   / Unable to adjust 3 pt top link #10
You say that the top link is as short as you can get it, are you sure that the toplink is the one for the 2230. A regular Cat1 toplink is about 5 inches longer than the Cat1 that is supposed to be on the BX. Don't know why your arms won't spread wide enough to get past the lower pins, the turnbuckles should adjust to let them go wide enough for Cat1 implements, the BX's don't have Cat0 TPH.
