OP
RobiBX2230
Ok there's your problem and that's why I suggest that at first you do it with the loader off the ground.
Because it's lifting the machine you back off before engaging float, it kinda scares you away.
If it's staying there when machine is off then you should be good to go, once you get the hang of it, it wont scare you and you'll do it confidently, but with the bucket on the ground it's a little harder cause it seems like your doing something wrong, also not sure but with the weight on it, it may be harder to engage float. if you do get it to go in with the front end up in the air it will crash down making you think you're really doing something wrong.
JB.
Thank you for the information - I'll have to try when and if I get the FEL back on - right now I have the front mount snowblower with a quick hitch - I should be able to get this into float also.... I hate to have stuff crashing down to the ground, yes it makes me think I'm doing something wrong.
