Results 41 to 44 of 44
10-10-2012, 08:59 PM #41Silver Member
- Join Date
- Oct 2010
- Posts
- 108
- Location
- Northern Virginia
- Tractor
- JD 6430Prem, JD 6400, JD 5500, JD4710, 955, 455
Re: Generator Transfer switch connection choices
Howdy,
I am only talking about the style of meter base. My local utility uses horn style ringless. There are many variations of the meter bases. Yes, UL approved, but you need to use the style and type that works with your utility. Yes, the utility will not move forward until the inspection is OK'd.Later Mike ~~~
JD green here
tractors and implements
10-10-2012, 10:13 PM #42Super Member
- Join Date
- Mar 2008
- Posts
- 6,483
- Location
- Northern Fingerlakes region of NY, USA
- Tractor
- Kubota L3830GST, B7500HST, BX2660
Good point. RG&E requires the same. Looks like GE 200 Amp 4-Space 8-Circuit Outdoor Combination Main Breaker/Ringless Meter Socket Load Center TSMR420CSCU at The Home Depot is the one that I would need (TSMR420CSCU). $108ish locally and takes the same interlock.
Aaron ZIf mankind minus one were of one opinion, then mankind is no more justified in silencing the one than the one - if he had the power - would be justified in silencing mankind.
John Stuart Mill
10-16-2012, 11:56 AM #43Gold Member
- Join Date
- Mar 2009
- Posts
- 307
I like this option a lot because I'm not spending a lot of money on a temporary transfer switch that would be unneeded some day when I get a generator big enough for the whole house. My thought was use one of these and then flip off all of the breakers I don't want to power before I start the generator. The one problem with this plan is this approach doesn't provide a meter that shows how much load I'm putting on the generator. Is there a way to put a meter on the panel that would be active when the the interlock is flipped and the generator in use?
10-16-2012, 12:42 PM #44Super Member
- Join Date
- Mar 2008
- Posts
- 6,483
- Location
- Tractor
I am looking at getting something like this: Gen/Tran Remote Metering Kit RMK-15-I RMK-15-F RMK-15-O and mounting it by the inside panel where I can watch the current usage and balance usage between the legs ahead of time.
John Stuart Mill
Similar Threads
generator/transfer switch connection
By geneP in forum Rural LivingReplies: 13Last Post: 10-30-2009, 01:48 AM -
Generator Generator transfer switch wiring diagram
By Barneyhunts in forum AttachmentsReplies: 46Last Post: 02-29-2008, 10:24 PM -
Wiring a Home Generator Transfer Switch
By RobS in forum Rural LivingReplies: 38Last Post: 01-27-2008, 07:58 PM -
generator whole house transfer switch
By automech in forum Rural LivingReplies: 17Last Post: 10-26-2007, 11:00 PM -
Neal's Generator/Transfer setup
By ns_in_tex in forum Build-It YourselfReplies: 43Last Post: 10-11-2004, 07:34 AM
