Xfaxman
Super Star Member
- Joined
- Feb 8, 2013
- Messages
- 12,922
- Location
- Guthrie, OK
- Tractor
- Toolcat 5610 G - Bobcat V417 - TORO+Loader
I worked a ton of hours in the woods with a tractor. I have an l4740 kubota and I loaded many 16 foot logs that was over a ton like this. I was wondering if somebody was going to mention this tactic.You could make a ramp out of 2 timbers, each with 1 end leaning against the side of the trailer and the other end on the ground, set wide enough to drive between. Then you can skid the logs to the ramp, then push them up the timbers onto the trailer. Something like this: <img src="http://www.tractorbynet.com/forums/files/owning-operating/394297-lifting-logs-log-ramp-jpg"/> Unloading would involve pulling them off, from the back. If you have a winch you can parbuckle the logs into the trailer.
Calculator be my friend:Math, be my friend.
A 36" diameter log is 1 cubic foot of wood for every 1.7 inches. Put another way, 7 cubic feet per foot. I come up with weights much higher, depending on density. Most hardwoods are around 40-45 lbs cu ft, but some like Live Oak are higher (60 lbs cu ft, yay USS Constitution). So @ 40 lbs cu ft an 8', 36" diameter hardwood log would weigh at least 2,248 lbs.
24" log is just about 7" per cubic foot (or about 12 cu ft for an 8' log), way lighter, about 480 lbs.
The fun comes in because of course the logs are usually smaller at top, may not be round, etc.
Unless you mill immediately you should REALLY plan on 8.5' or 9' so you can trim the ends for splitting. I usually do up to 10' because that's what my LT10 handles easily.for milling my own lumber, I just like 8 footers for what I do. 8ft isn't a hard number I have done longer logs but was just stating what I mostly use.
He's got it right PARTIALLY. I use rear pallet forks but FEL forks are much more adaptable. That's why I bought my M4700, lifts a ton on the front, 2 ton on the rear.Arrow has it right. Buy a set of pallet forks for the 3 pt and lift your heavy logs with that. For $250 you can save yourself a lot of potential damage on the loader and front end of your tractor. Why do you want to plan on pushing it to the limits?
<snip>.
