chabat124
I just bought my 1st tractor. I have a lot of questions. 1952 Ferguson TO30. Going to be mowing a 2 acre field and very light dirt work.
1) Throttle: It is very hard to regulate. It seems to go way high in the rpms in just like a 1/4" movement of the throttle lever. Seems like I fight with the throttle, to keep it from bogging, to keeping it from going to high. Is this inexperience, or a problem?
2) I tried brush hogging today with the rotary mower (flail?). I broke the back wheel off. The wheel kept getting stuck dragging sideways until it just snapped off the shaft. I can weld, but I don't know why it would be binding in the first place?
3) When I set the height on the mower with the hydraulic lever, it slowly lowers on it’s own within minutes. How am I supposed to keep the deck at the right height/off the ground when it is lowering slowly on it’s own?
4) Once I got the deck too low and it was bogging the engine almost to a stall. But since the hydraulics and the pto work together, I could neither raise the deck or move forward, the tractor did not want to drag the mower deck while it was sitting flat on the ground.
This is so much harder than I thought it would be. I am starting to think I can’t operate an antique tractor. Frustrated.
Chris (TX)
Chris (TX)
