California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 14,697
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
Ditto. That identical motor/compressor is on my HF 10 gallon horizontal compressor, a recent previous model. It is unpleasantly loud.I have this air compressor from HF....
21 gal. 2.5 HP 125 PSI Cast Iron Vertical Air Compressor
It is absolutely the loudest air compressor I've ever heard
And the shroud on mine is open toward the regulator which megaphones the sound out where you are working. Good design in that you see the oil level every time you turn the switch on, but man what a racket.
I see the present version 2.5hp/10 gallon has the shroud pointed away from the regulator. Maybe that's a little quieter but who is going to roll the compressor out of the corner of the shop (where you put it because its so darn loud) to look at the oil sight glass?
Incidentally I found a Youtube demo of the 2.5hp/10 gallon compressor and the guy seriously misses the point. Like my experience, that compressor won't power HF's $30 impact wrench but it is because that tool sucks too much air. My solution was I got rid of that impact wrench and bought the $80 Earthquake model. This works beautifully. I can do several lugnuts before it kicks in and the torque is incredible. That reviewer doesn't realize his problem is the inexpensive and air-hungry impact wrench he is trying demo. I see HF no longer sells that model.
That reviewer also says 2.5hp/10 gallon is insufficient for spray painting but he hasn't tried it. Wrong, it powers HF's $10 HVLP spray gun beautifully. We primed then put a gallon of white Rustoleum on lawn furniture recently (photo) with this combination. It paints for quite a while before it kicks in, and recovers in under a minute while you continue to spray without stopping.
Finally this compressor ran my old Porter Cable framing nailer at the far end of a long air hose just fine.
Overall, the 2.5hp/10 gallon rig meets my needs. I just wish it wasn't so loud.
