strum456
Now that we have finally established that the pto spins with the tires on the ground and the transmission in gear, we can rule out the clutch as the immediate problem (like SoundGuy said). There is zero possibility that your tractor has a double clutch.
Will the tractor move with one broken axle? Definitely not. The differential will always send the power to the tire with the LEAST resistance. A broken axle would be that path. Keep in mind that a broken axle might grip enough at the break point to appear normal under no load.
Try jacking up one tire. With the trans in low gear, attempt to forcably turn the tire that is off the ground. Rock it back and forth as hard as you can. There is a good chance that you will notice something slip and possibly HEAR where it is coming from, since the machine is not running.
Dont take your loader off yet. Knowing what we do at this point, I am putting my money on a broken axle or stripped axle splines. Let us know what happens.
