Need 3610 Ford Tractor - CVA fuel pump rebuild kit
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #1
10usdad
Kingsport
Ford 3610
Need to rebuild a leaking throttle and cut-off. Suggestions where to look for CVA fuel pump rebuild kits. Thanks in advance.
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #2
Take the part/model number information) off the pump and then google it and you should be able to come up with something.
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #3
:welcome:
To the forum from Alabama.
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #4
That would be a CAV pump.
All you need is a cover gasket and 4 of a single part number of o-ring. As a New Holland dealership parts manager, I stock those two part numbers, and IIRC what you need would sell at or near $10, maybe less.
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #5
Messicks prices are as follows:
Gasket PN is 381771R1 $9.93
o-ring PN 49886 @ $.63 ea.
Before you remove cover completely take note where spring is attached on both ends. I think I've read that there are u-tube video's on the internet on replacing the o-rings
Why is there wires that attach the two nuts that hold the top cover on the CAV fuel pump? What purpose do they serve?
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #7
They are a factory seal that proves nobody has made any adjustments to the fuel delivery rate or other settings. There is a lead seal crimped over the ends of the wire.
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #8
welcome to tractor by net you show home city as kingsport if this tn you can call acme diesel in knoxville 865-524-3005 they will need some numbers off your old one good luck
   / Need 3610 Ford Tractor - CVA fuel pump rebuild kit #9
I did that same job in my dozer - not bad at all. Look at these
https://www.youtube.com/watch?v=AYz0dCQNiVc
http://www.tractorbynet.com/forums/massey-ferguson-classic-vintage/258591-mf-165-knocking-9.html
This is my dozer
The hardest part for me was getting the cutoff lined up with that shepherds hook you can see on the back left. Took me 3 tries. Just don't tighten the nuts to much until you know it is in.
Thank you very much. Great pictures showing procedure! Very much appreciated!
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
2025 KMR 40in Single Cylinder Grapple Skid Steer Attachment (A51691)
2025 KMR 40in...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
