2 Stage Clutch adjustment
   / 2 Stage Clutch adjustment #1
Syncro
NW Nevada
MF 1532, Kubota B-26 TLB
For those that may want to see how a 2 stage clutch is adjusted I've attached a picture that shows the simple proceedure. This particular tractor is a Ford, but its similar to others. If the clearance on the 2 stage clutch pack is not correct the PTO will either not release, or not engage. It requires using a feeler guage to set. On this machine the 3 adjusting bolts are visable through a side cover and its just a matter of loosening the lock nut and turning each bolt in or out to get the required clearance (.030" on this tractor) The flywheel can be turned using a long screwdriver, hammer handle, or similar pry bar. I center punched each bolt for ID so I wouldn't get em mixed up. Simple, once you know how. /forums/images/graemlins/laugh.gif
   / 2 Stage Clutch adjustment #2
Synchro
I must thank you for some really simple and direct instructions in your 2006 post on 2stage clutch adjustments. I am a motor mechanic by trade but doesn’t help whatsoever when it comes down to requiring dimensions to repair any particular job. I must have searched everywhere for the information that you finally provided and trust me there are some fools out there and even more misdirected ones that believe them. I even found a post for eBay offering to sell me a CLUTCH ADJUSTMENT. It all comes down I believe (with the net) to asking the correct question. My son owns a dilapidated Shibaura sd4340 which he has be using for some time and it has developed a problem with the 2stage clutch. I soon found the adjustment hole and the 3 bolts you mention but had no starting point for an adjustment and now I do. So thank you again and the old tractor can wander off into the mist again sounding just like the Manly Ferry.
Greg Page.
2016 CHEVROLET 3500HD SERVICE TRUCK (A54756)
2016 CHEVROLET...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A53843)
HYDRAULIC THUMB...
2006 NEW HOLLAND L185 SKID STEER (A52705)
2006 NEW HOLLAND...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
