Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Join Date
    Aug 2010
    Posts
    62
    Flatistan and Tenn. (part time)
    PT 425 & john deere hydrostatic, DR Brushcutter 17 HP!!!!
    Default Homemade Log Grapple
    Here are some photos of log grapple just finished, but not painted yet, that can be used on the front or back of the PT425. Attaches with standard tow bar square tubing and pivots in all directions as needed. It pivots 90 plus degrees depending on needs by just opening the jaws and nudging the end of the claw against a tree or log, the horizontal and vertical pivot tension is adjusted with 1" nylock nuts. The pivot mechanism is made from a four inch pipe 90 and blind flanges with one inch studs and nylocks. It opens about 36 inches and will pick up brush or logs as much as the PT will stand.
    Used thin plywood patterns and finish nails to work out the geometry before cutting metal. Got the hydros from Surplus Center. Being articulated,the PT is excellent at small scale logging work
    Attached Thumbnails Attached Thumbnails Homemade Log Grapple-044.jpg   Homemade Log Grapple-048.jpg   Homemade Log Grapple-051.jpg   Homemade Log Grapple-054.jpg
  2. #2
    J_J
    J_J is offline
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,469
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Homemade Log Grapple
    Nice work, innovative.
    Are you considering a swivel head on the grapple?
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    KMA
    KMA is offline
    Gold Member
    Join Date
    Sep 2006
    Posts
    276
    Owego, NY
    PT422 w/ EH72FI engine swap
    Looks great!
  4. #4
    Gold Member Clumber's Avatar
    Join Date
    Sep 2010
    Posts
    322
    Northern Virginia
    PT425 (Dec 2010)
    Quote Originally Posted by FAZTRAC View Post
    Very nice! But I don't understand how it can be used on the back of the PT 425?
    I married me a hippy, ran away with a stringy haired blond,
    Now we're both old and happy, fishing on our own Golden Pond. -- Merle Haggard
    PT 425 (Dec 2010), Blade, Snow Blower, Sweeper, Spreader, LMB, 4n1, Small Bucket/Teeth, Utility Grapple, Brush Cutter, Box Blade, Mini Hoe/Thumb, Forks, Power Dumper
  5. #5
    KMA
    KMA is offline
    Gold Member
    Join Date
    Sep 2006
    Posts
    276
    Owego, NY
    Quote Originally Posted by Clumber View Post
    Maybe for clamping down and dragging logs?
  6. #6
    Elite Member BobRip's Avatar
    Join Date
    Sep 2004
    Posts
    4,034
    Powhatan Va.
    2000 Power Trac 422
    Nicely done. Can we see a picture of it on the back.
    Bob Rip
    Tell me and I will hear.
    Show me and I will see.
    Let me do and I will learn.
    Let me fail and I will understand.
  7. #7
    Join Date
    Feb 2009
    Posts
    198
    south western michigan
    pt 425
  8. #8
    Join Date
    Sep 2004
    Posts
    4,034
    Powhatan Va.
    2000 Power Trac 422
    You could put a bucket on that and make a minihoe.
    Bob Rip
  9. #9
    Join Date
    Aug 2010
    Posts
    62
    Back attachment gear is not finished. The grapple will definitely be on a swivel on the back end (see padeye welded at balance point) and will operate off a small hydraulic derrick that just lifts it up and down for lifting and dragging logs with wheels on the back end of the logs since the PT doesnt have much ground power. Will use electric solenoid valves for the back end connection with two joy sticks on the over head of the ROP/ One stick for the derrick up and down and the other to open and close the grapple. A guy gave me the 12VDC tandem solenoids, so ready to go with that, will just hook them into the hyd. circuits back in the engine room so will just have to run a couple of wires up forward to the overhead spring centered switches. Its all fun.
  10. #10
    Join Date
    Jun 2006
    Posts
    59
    Dayton, Pa
    Power Trac 425
    Just curious, how much do you think it weighs?
Similar Threads
  1. W.R. Long kit plus Gator grapple
    By jcliburn in forum Kubota Owning/Operating
    Last Post: 12-10-2012, 09:29 PM
  2. 4120 Log Grapple
    By dconine in forum John Deere Owning/Operating
    Last Post: 01-11-2011, 02:42 PM
  3. Log Arch - Homemade
    By savageayape in forum Build-It Yourself
    Last Post: 08-18-2009, 03:22 PM
  4. Homemade Log Loader Trailer
    By wkheathjr in forum Customization
    Last Post: 11-14-2008, 09:10 PM
  5. Grapple Install
    By BamaRob in forum Attachments
    Last Post: 11-26-2007, 03:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
