acreage............can anyone tell me the acreage on a piece of prpoerty that is.: 125 feet X 1017.36 X 47.47 X 1052.62 ?
We must have posted near the same time, I provided the survey map if it came thru for everyone.Four dimensions don't uniquely determine the shape of the lot, you need to provide one more piece of data. It can either be one of the included angles, or the length of one of the diagonals connecting two corners. If you can get one of those pieces of data, I will figure it out for you.
Thank YouHeaded out the door and I'm getting tone about being late, that's enough data to get the answer. Will try to do tonight when I get home.
The deed calls for 2 acres and 11 perches, but the measurements on the deed are: 125 feet X 1009.8 feet X 47 1/5 feet X 10048.4 feet, but the new survey is with the previous measurements, and is calculated at 1.9782 acres.
No, that isn't mine.If it actually says "2 acres and 11 perches" that's like saying 2 acres and 110 feet. A perch is a unit of length, not area.
If it meant square perches that could be about .07 acre.
Is that the piece mentioned here?
i own 2 acres 11 perches of land off ridge ave in ... - Zillow Real Estate Advice
