Woody65
Gold Member
- Joined
- Mar 20, 2012
- Messages
- 482
- Location
- East Northport and Oneonta NY
- Tractor
- John Deere 4300 HST 4wd
Pclausen,
I have installed the fascia trim exactly as your builder is doing thousands of times without there ever being a problem. I am from the Northeast and we have plenty of ice dams in the winter. Nice house and great thread!
dave1949 said:What are the pros and cons of that method?
I am having trouble seeing the advantages
These are the things that would worry me:
The shingle edge looks a bit ragged.
Wind-driven rain could go between the trim coil and shingle underside unless caulked.
The trim coil could do some soda canning and break that seal if it is applied.
A ladder without a stabilizer resting on the shingles will dent the shingle edge.
The effectiveness is the same as a drip edge but it has a much cleaner look aesthetically.
I believe we are looking at a gable end and that is why it looks that way as opposed to the gutter/fascia end which would have a much smoother look.
If the metal is bent properly on a brake the underside of the shingle lays tight to the return bend preventing any water from entering.
I have never applied any sealant to this area.
A gutter should cover and keep a ladder from crushing the shingles. If a ladder is on the gable end, I have dented drip edge along with the above method if not careful. Around here drip edge is only used by homeowners or someone without a bending brake to custom make your own aluminum trim.
Hope this helps explain some of the above.
I don't see your point with this post. All that I saw that I think to be relevant was:
--Place metal drip edges or wood starter shingles over the membrane.
What is your point exactly?
