LOL...!
Jeeze, i didn't mean to stir y'all up. No it is not a Turkey or a cat, it's Annie our Welsh Terrier, although we do call her "Chimpannie" because she climbs anything, makes chimp-like sounds, crawls up and will sit on your shoulder...etcetc.
Now for the framing: it is 2x6 PT. There is a double header above the french door opening, and there will also be a 2x6 on edge on the inside (supporting a 10x14 loft) and on the outsidea 2x8 supporting a 14x6 tin roof. You can't see it much in the photo, but i have used heavy galv strapping to lock the top of the wall, pulling it against the inside of an arch curve. The strapping spans 2 arches before being screwed to the wall. The 2x6 sole plate is bolted to the slab using a 1/2 x 8" red head every 2 feet. I am using 7/16 OSB on the outside and inside(no sheet rock), it's strength is length wise, so, no i did not frame it all the way around, and besides, it will only be supporting vinyl siding. Pic's to follow............
The angles were/are a challenge, because they are all different as you go up one side, so my wife and i made templates on the first side which we will use on the other 9 sides(2 outer walls and 1 interior wall). If it caves-in it's gonna take a heck of a wind..........
RD
