Kubota L4330 - Loader bolts missing / threads mashed / stripped threads
   / Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #1
nvr-enuf
Hello everyone,
I have a L4330 with the larger loader and for some reason my unit has loosed the lower loader bolts as well as in some of the bolts mushed the threads to the point that the threads have stripped.
I do have the additional brackets to support the ability to mount the sub frame when removing the loader to put in place a snow blower.
The threads are fine pitch - first of all, does anyone know the size of these mounting bolts?
Any idea why my bolts are loosening?
For the threads that are stripped, I will have to drill out and re-tap to the next largest size.
Scott
   / Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #2
Before drilling out, I would try to chase the threads that are there with a fresh tap. Go slow and clean the tap often. There is some debate among engineers as to how many complete threads are actually needed to hold full bolting torque. I've heard as few as 3 and as high as 6 threads. The point being that that you may be able to torque and use the damaged threads. Loctite has largely taken over from the old fashioned lock washers. Nothing beats safety wire.
rScotty
   / Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #3
You need 1x dia. for thread engagement. Use blue Loctite.
   / Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #4
Hello everyone,
Scott
Yes. Something is wrong with the setup of the loader on the tractor. Sorry that it is impossible to be specific, but some possibilities are:
#] It does not fit the tractor exactly and correct shimming or other measures were not taken to assure neutral compliance at all fastening points.
#] The loader frame is missing some bolt in brace elements.
#] Correct fasteners and hardware, washers, etc were not used
#] Any or all fasteners were never tightened. These bolts are meant to be very tight. Check specs.
,,,The last is the most likely to be a sole cause, but combinations with any or all would ensure speedier failure.
Who installed the loader?
larry
   / Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #5
You may need to repair the threads with a heli-coil.
   / Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #6
Heli coil repair is not suitable for threads in that type of service
   / Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #7
They have been used by others here that have had the same problem with success. We use them at work all the time and I've never heard of a limitation. Do you have documentation? I would like to read up on it.
   / Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #8
Do the existing bolts go all the way into the hole or are there threads not being used by the bolts further into the hole? I ask this because I had the same problem on my loader, and found that by lengthening the bolts with new ones that used the whole hole depth I was able to grab more threads, and thus tighten the new bolts tighter, with red locktite. Problem solved. Fortunately I got to it before the thread holes were totally mangled. I replaced all bolts on both sides. In this case it was use of too short bolts by the manufacturer, and I confirmed with my dealer that when they get too far gone they have to remove the loader and do a bolt and nut routine. Way too much work for such a simple problem- if only the right length bolts had been used to begin with....
   / Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #9
Murphy, that's a nice rule of thumb; I like it enough that I often use it myself. My thought is that rule came into popular use because it is a nice approximation of the thickness of the standard nut for each bolt....and how could that be wrong?
But it isn't the last word.
If you want to go into more detail, check out:
trwww.engineersedge.com/calculators/iso-minimum-thread-engagement.htm
There calculations come closer, but there's problems with that approach too.
Scott, it's a nasty problem. There might be "helicoil type" inserts that would work; I don't have any experience with them. But they all require hand-tapping into the cast engine block material and that would be a problem all by itself. Last resort.
I like the fix that Coyote came up with. Somehow you need to get a bolt out and measure the depth of unused thread in the block. There will be some.....hopefully there will be enough. Then decide what thread you have and go to McMaster Carr to get some.
Now the choice is whether to use a new tap and carefully chase out the damaged thread. As to how to do the thread restoration.....
I've actually had better luck restoring damaged threads by not using a commercial tap at all - commercial taps are too sharp with too much cut and not enough thread support. Too easy to get them started wrong and they will cut regardless of right or wrong.
What I do is better and costs less. Take a hardened bolt of the right thread and size and cut half a dozen slots with a hacksaw perpendicular to the threads. Cut the slots about an inch long and somewhat deeper than the minor thread diameter. Now carefully taper the bolt for the first couple of threads. If you want, I can probably find an old bolt I've done this to and post a picture. This becomes my handmade thread restoration tap. It is way better for the purpose than a tap. Start it straight, go very slow with lots of light lube, and the real trick is to back it out to clean the particles with a hand wire brush quite often. Sometimes I back out every 1/8 turn I gain....or even more often. Constantly cleaning the particles out of the hand-made restoration tap is critical to doing this job. Each time you back the hand-made tap out, Use WD-40 and a nozzle to foam out the particles left behind in the thread bore.
When done, try to thread in the longer bolts you bought - best source for those might be at McMaster. With luck, there will be enough good thread to hold the torque. That's not quite as good as new, but I can't think of a better solution. Be careful not to use too long of a bolt. You'll probably have to cut them to special length. Use hardened washers. Measure to leave a little free space at the end. You sure don't want to go too deep and crack the casting.
What a pisser. Yes, the original bolts were more than likely poorly installed. This is as good as I can come up with. Don't give up on the threads you have until you've tried every way to get them into use again. Anyone else?
luck, rScotty
   / Kubota L4330 - Loader bolts missing / threads mashed / stripped threads #10
It is a known fact that the loader frame bolts need to be checked routinely when the rig is new. I believe it is mentioned in the owner's manual.
Hr:2185.1 jihn Deere (A56857)
Hr:2185.1 jihn...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
Portable Restroom (A54865)
Portable Restroom...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A57880)
2007 FREIGHTLINER...
CATERPILLAR 299D3 SKID STEER (A52709)
CATERPILLAR 299D3...
