Results 1 to 10 of 21
09-02-2012, 05:56 PM #1Veteran Member
- Join Date
- Jul 2008
- Posts
- 2,384
- Location
- Bay Roberts, Newfoundland, Canada
- Tractor
- Custom 2011 Kubota 5740 HSTC-3, Grand Cab. Yep. Life is grand! 2013 Kubota BX25D.
Arctic Poly Skin
Our TBN member (RFB) asked me to show him the poly skin I have on my blade so rather than post it on someone else s thread I'll post it here.
This is a poly plow I had on my old pick up that I later modified to fit my Kubota 4240 and now my Kubota 5740. The poly skin can be purchased at a Arctic Plow dealer and you'll have to cut the steel skin off your blade and adapt the blade frame to accept the poly skin. The skin's thickness is 3/8th thick and snow will never stick to it so that's why I like it so much. We get a good bit of wet snow over here and this blade takes care of that.
I also added a kick back shock to the blade as well because there were times the blade would recoil and flick snow and ice back towards the windshield. The shock took care of that issue. The blade comes back nice and easy now making it much safer.
I also added rear skids to the "A" frame to prevent the rear of the blade from digging into the pavement. Here's is a link to the original thread.
http://www.tractorbynet.com/forums/c...apted-fel.html
Lower rear skids
Front skin
Front shock
...Excellence is not just a skill. It is also an attitude...
Photo's of my restoration work and tooling: http://www.flickr.com/photos/15602393@N05/
YouTube Video's: http://www.youtube.com/results?searc...rch_type=&aq=f
2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
2013 Kubota BX25DTLB With Wallenstein BXM32
Kubota ZTR ZG 222 Z
09-02-2012, 06:22 PM #2Platinum Member
- Join Date
- Jan 2006
- Posts
- 871
- Location
- West Central Idaho
- Tractor
- Grand L5740HSTC, Kubota LA854 FEL with QA Bucket
Re: Arctic Poly Skin
Paul,
Is there a skin made for, or a way to put a poly skin onto an existing steel skin (I run a Curtis 7.5 in the attached pic.)
Thank you sir!
09-02-2012, 06:40 PM #3Veteran Member
- Join Date
- Jul 2008
- Posts
- 2,384
- Location
- Tractor
Kubota ZTR ZG 222 Z
09-03-2012, 01:22 AM #4Super Member
- Join Date
- Aug 2006
- Posts
- 5,114
- Location
- Front Range of Colorado
- Tractor
- JD 4200 C.U.T. & JD 130L Lawn tractor
Somebody sure has been busy getting ready for winter.
Моє щоденне меню для терористів: бекон на сніданок, бутерброди з шинкою на обід, і вечерю свинячої відбивної
Stuff I've made for the JD4200 or done with it are at this link. http://picasaweb.google.com/mjncad
09-03-2012, 02:57 AM #5Veteran Member
- Join Date
- Jul 2008
- Posts
- 2,384
- Location
- Tractor
Na. The tractor is ready but I am working on one small mod right now that's pretty neat if I must say so myself. The shop is still going full tilt and we got the big wedding day in a few weeks for our youngest Navy son so I have to concentrate on the wedding car and a hundred other wedding related things
Kubota ZTR ZG 222 Z
09-03-2012, 07:31 AM #6
I have seen what you are talking about before but cant seem to find a link at the moment. I think I have seen them in the discount-snowplow-parts catalogs I get. It is basically a thinner poly skin that gets glued over the existing steel skin. I'll keep looking and see if I can fidn a link.
".........there is only one way to find out."
"Ok, hold my beer and watch this.........."
Ford 5500 Backhoe
Kubota L3400GST W/LA463 FEL
2005 Dodge 3500 4x4 Diesel
8N Rebuilt and restored
Bushhog 105 and 306 cutters
JD 261 3PH mower
3 Homemade wood hauling trailers
Dolmar 7900
Dolmar 6400 84cc ported BB kit and Muffler Modded
Sachs-Dolmar 120SI Ported
(4) Sachs-Dolmar 116SI Ported
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
09-03-2012, 07:46 AM #7
Found what I was looking for. Non-Stick Snow Plow Liners
There are others that make them too. You can do a search for "poly snowplow liner" and come up with a ton of stuff".........there is only one way to find out."
Ford 5500 Backhoe
JD 261 3PH mower
Dolmar 7900
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
09-03-2012, 07:53 AM #8Veteran Member
- Join Date
- Jul 2008
- Posts
- 2,384
- Location
- Tractor
I haven't seen the glue on ones but you could buy a sheet of Teflon and do the same. Here is the link to Arctic Plows. You could email them and ask how much for a replacement skin.
Arctic Snowplows - Accessories...Excellence is not just a skill. It is also an attitude...
Kubota ZTR ZG 222 Z
09-03-2012, 08:01 AM #9Veteran Member
- Join Date
- Jul 2008
- Posts
- 2,384
- Location
- Tractor
Here's a video of the Poly blade and a parts break down.*
http://www.arcticsnowplows.com/engli...D-P_manual.pdf
Arctic Snowplows - Videos...Excellence is not just a skill. It is also an attitude...
Kubota ZTR ZG 222 Z
09-03-2012, 08:49 AM #10
Yea, maybe I was mis-remembering?? The link is the ones I was talking about. I never paid much attention (and never used them), so I just assumed they glued on. But now I see that they get bolted on at the top, pinched under the cutting edge at the bottom, and silicone to seal and kinda act as a glue for the middle.
Ford 5500 Backhoe
JD 261 3PH mower
Dolmar 7900
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
Similar Threads
Arctic Cat Questions
By farmboy12 in forum ATVs & Utility VehiclesReplies: 7Last Post: 07-27-2009, 06:28 PM -
Arctic Cat UTVs
By Avondale in forum ATVs & Utility VehiclesReplies: 1Last Post: 03-16-2009, 10:48 PM -
What not to do with your Arctic Cat Prowler...
By Dmace in forum ATVs & Utility VehiclesReplies: 20Last Post: 10-21-2007, 11:43 PM -
Skin for a 'Gatorbox
By LazyK in forum John Deere Owning/OperatingReplies: 0Last Post: 03-04-2002, 09:24 AM
