Obed
Elite Member
The electric liquid tape works great for protecting the wire from moisture. When I lived on the coast, I used that stuff to cover wire splices on my sailboat. I never had any problems and that was a saltwater environment.
Sure you can solder your connection; it won't hurt anything. However, I think that might be overkill. Look under the hood of your car and look at the wiring done there. I'll bet you that GM didn't solder all the connections. Unless your wire is under stress, splicing the three wires together with the wire connectors that look like a cone should work fine without solder. If the splice comes undone, you can always solder it later.
Cover the wire connector with electric liquid tape and I'll bet you'll never have a problem. If you took your UTV to the shop and had them install the switch, I'd guess that they wouldn't solder the connection. We're talking 30 seconds of work versus 5 minutes if you solder it.
Obed
Obed
