RalphVa
Super Member
- Joined
- Dec 19, 2003
- Messages
- 7,873
- Location
- Charlottesville, VA, USA
- Tractor
- JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I use 5w30 M1 in my lawn mower engines. Should be fine for your Onan air cooled. Think the only difference between diesel and gasoline engine oils is extra detergent to keep the soot in suspension on diesel oils. Diesel oils can be used in gasoline engines, if the 15/40 is what is speced and still under warranty, just use what you use in your tractors and then when off warranty, switch them all to 5w30. That's what VW had speced for use in its diesels for many years. Castrol 5w30 from VW is what I use in my JD and Isuzu diesel engines here in Va. Plan to switch to 0w30 M1 ESP when I'm out of the Castrol stuff because I'm an Exxon Mobil guy who worked in lube oil industry for 31 years and know that M1 was always the best. (Never saw any tests on the Group V stuff that's out there now. Bet it's just as good. Don't think it was there much when I was working, pre 1998.)
Ralph
Ralph
