I put new hydraulic pump in 180 mf 3 point will lift now [slow] but outlets only has 300 psi. the guy who put it in is lost and don't where to go now need help time to hay BUCK
MF 85 diesel, TO 35 diesel, 165 diesel, IH Hydro 84 diesel, MF Super 90 diesel puller, Agri Power 7000, 8000, and 9000 diesels, MF 205 diesel
How well does the Multi-Power work, if tractor has it? Auxiliary pump is two stage on MP models, larger gear set for auxiliary and smaller set for MP. Does the pressure change with engine speed? There may be a line elbow popped out of the PTO shift side cover, that happened to dad's 180 years ago, can't be seen until the lift cover is pulled..
