AlbionWood
Bronze Member
The dreaded and hideous "electrical problem..."
Actually more than one problem, but I suspect they are related.
Instrument panel isn't getting any signals from the fuel tank, oil pressure, thermostat, or alternator. All dead.
Fuses are fine. Can't find any chewed wires or breaks. Took the fuses out and tested across the terminals, with key on but tractor not running: 12V across each of the 10A fuses, but only 6V across the 15A fuse.
Took off the instrument panel, cleaned out the mouse nest behind it, opened the plug connector and tested the various circuits: Less than a volt across each pair of pins.
The tractor starts and runs just fine. The alternator does not seem to be keeping the battery charged though. It has an Optima AGM in it and after a lot of use, the battery will lose power and eventually won't start the tractor. If I jump-start it and run it for a while, it does not regain charge. I've been using an old Sears charger periodically to keep the battery charged.
The only thing I can think of is maybe a relay has gone bad. Anyone have other ideas, or suggestions for additional diagnostics?
