Do you have a cover on your starter. If it was left out water could have got in the starter. Take the band off of it and look inside. There should not be any rust on the comutator. If so it could be drawing too much power to try to overcome the resistance.
Thanks Don I will take that carb off this afternoon and take a look. And yes Mike there is a cover over the starter, but I will look inside itjust to be sure. If I do find that water got in and rusted the comutator is there a way to clean them, like a wire brush or something or will I need to replace the whole starter?
T If I do find that water got in and rusted the comutator is there a way to clean them, like a wire brush or something or will I need to replace the whole starter?
I would take it to your local auto electronic re builders. I took mine off my Case in and had him turn the commutator to remove the rust and put a new bendix and gear in it. Cost about $55.
I have checked my carb and starter and they are fine. With the help I have gotten on this forum I am now able to get the starter to work. But that is all. The starter comes on and spins the fan blade but it just wont start the engine. Any ideas ?
Like SOOTS said above,you need to investigate the spark and compression.Pull a spark plug and holdit to ground at its tip,Use a rag or heavy glove to keep from getting a shock,LOL!.Crank the engine and see if you're getting spark thru it.
If not,or a weak,yellow spark, you may have corroded points,weak condenser,bad spark plugs, or weak coil.
Engines of old didn't need to crank fast to start up.But as SOOT said they need those things,so while you have your spark plug out,check compression in that cylinder.
Always remember to set the throttle open when checking compression. don-ohio ^)
I have a 1952 massy harris runs good but now wont start, have checked battery, cables, new starter, new ignition, good gas. bought wire probe, all wiring is good. whats next?
