kidroc2133
- Joined
- Dec 5, 2020
- Messages
- 4
- Tractor
- John Deere 310D
I have a 74 JD 310-D. It sat for about 5 years before I purchased it. All things I have done so far is drain the diesel out of the tank, the lines and the injector pump also changed out the injectors and put in a new fuel/water filter. Injector pump screen was pulled and cleaned (wasn't that dirty) also cleaned the little glass ball fitting on the return line coming from the top of the injector pump (wasn't dirty either) no little black pieces came out of the injector when I drained it from the little window that I could tell. I will not start unless I use some ether in it and I have to get enough ether in it to get it to a high enough rpm for it to actually stay running. When it does run its at a high rpm not a normal idle even after running for 5 mins or longer rpm never drops to idle speed. The accelerator pedal does rev it higher. It does run on its own when I get it to that point. Only thing now is when I try to put it in gear and move it, it will stall out. Motor was rebuilt before it sat. Guy told me that maybe 300 hours on the rebuild. Hydraulics work when its running. He did say that the injector pump worked it self loose a few times. So, could the timing be off on the injector pump that its causing the hard start / high rpm after starting?
Any knowledge you guys may have on something else I might be missing or does it sound like a timing issue?
Thanks.
Thanks.
