Kubota is excellent. I worked mine really hard and managed to wear it out in 2500 hours. However, if you are doing a lot of lifting and considerable ground engaging work, consider a heavier tractor in that power range. I would suggest looking at Mahindra. At the same engine power, Mahindras weigh more, have higher loader and 2-point lifting capacity and larger tires and axles than Kubota. However, heavier tractors burn more fuel doing such things as bush-hogging, as it takes fuel to move that extra weight around. Also, go for hydrostatic drive. It is safer in the woods and works well with FELs. Just my 2 cents worth.I’m in the market for a 35 HP tractor and I’ve done a lot of research as a first time buyer.
The tractor will mostly being used for dirt work around the house (2 flat acres) and lifting items with the FEL. I also have 100 acres of hunting property to brush hog roads/shooting lanes, and plant about 5 acres of food plots.
Dealers seem to be a hot topic when it comes to tractors so I’ve narrowed it down to these, their time selling the tractors and distance from me.
YT235 - 2 dealers (1 has been selling Yanmar for 8 years and is 25 miles away, they only sale yanmar products). Other one is 40 miles away, didn’t get details on selling time
Kioti ck3520SE - 27 miles away, only been selling Kioti for 8 months.
Kubota L3302 (or L3902) - 2 dealerships within 20 miles. Been selling as long as I can remember.
Anyone have any experiences with these tractors, part availability, etc? I’d be doing as much repair work myself as possible.
I mowed 1 acres per hour with a 4' bush hog on my Kubota B7100 HST, and 1.5 per hour on the lawn with a finishing mower. That was only a 16 Hp tractor. I now do 5 acres of bush hogging per hour with an 8' dual spindle brush cutter on my Mahindra 5035 HST. That is a 49 Hp tractor. So I find 2 acres/hour to be credible with 35 Hp. BTW, an HST actually can cut faster, because you can speed up when the cutting is easier and slow down when needed. The gear drives tend to be set at a speed that works in the toughest spots.I would be shocked at a 35hp tractor mowing two acres an hour unless it’s a lawn.
My kioti 7320 is a shuttle shift. They actually call it a power shuttle. You dont touch the clutch to go from forward to reverse. Clutch only for changing gears. Three ranges of gears 1-4 in low medium and high. I have never put it in high range. If I am going from one sidenof the property to the other, on the driveway I will put it in 3 medium. If I’m carrying something on FEL 1 or 2 medium.Well, it isn't the same for all.
I've never heard of a shuttle that needs clutching. It would seem to kind of defeat the purpose. But there you are, and you own one called by Kioti? as a "syncronized shuttle"...and it needs clutching. That doesn't make Kioti's requirement for clutching universal.
My wife's YM336 Yanmar worked differently, and our old 3020 JD worked differently too (picture below), and our newer JD works differently from both. It doesn't even have a foot clutch. Yet all of those were shuttle and power shift combos.
The confusion is one we've seen before. There just doesn't seem to be a standard terminology for that type of geared transmission using a hydraulically powered shifter and clutch. That problem with how to describe something happens a lot in mechanics. Kubota calls their version the "Glide Shift". It seems to depend a lot on how a manufacturer - or their advertising translators - decide to describe the features of their own version of power/shuttle shifters.
What's more important to me is how how a particuar system works in a particular brand or model. Simply calling it a name doesn't mean much when different brands use the same wording to mean different things. In the posts in this thread I was comparing YM model Yanmars from generations 40 years apart to help the OP understand what to expect from that sort of transmission. It wouldn't surprise me if there were different models in between that worked differently.
rScotty
The video of the NS loks to me like Kioti took Bobcat upgrades and added them to this line at least . Bobcat is just a rebranded Kioti and they did this to Bobcat back arournd 2012 and forced Bobcat out of the tractor bussiness for a few years . If you go back to those years you can see that Bobcat made 500 upgrades to the Kioti or at least they claim they did . The one thing I can say for sure is that the front end on the Bobcat in those years was built way heavier than the Kioti .I think you would be thrilled with any of those choices. I agree that the best thing is to make several visits to look them over and do test drives. You will learn something every time.
My thoughts from a distance
Kubota is a great tractor, but I don't like the Micky Mouse hydro treadle. This is their economy model
Yanmar makes great tractors - how is the price
Kioti - might have the most/best features - most bang for the buck
That said, any of them would be great
If you are looking for something larger, that Kioti NS series is kind of like Goldie Locks - just right
