Highbeam
Super Member
Thanks for this good information. If I understand it correctly the safest maintenance I can do is drop the pan and change the filter and however much fluid this changes out. If in fact there is a drain plug it seems like draining it 2 or 3 times would be a good idea.
I have noticed the last few months in the cold weather there is some tappet noise until it warms up. Does this indicate they should be adjusted, or maybe something worse?
That's not tappet noise, it's called Cold Start Knock, and is very common on the 6.0 vortec and less so on the 5.3 vortec in your yukon. It is normal and supposedly is no reason for concern. They say it is caused by the pistons rattling around in the cylinders and since these modern pistons have very short skirts, they rock around a good bit when cold.
A little extra time warming up makes me feel better about driving with that CSK.
You'll get about 5 quarts of the 18 quarts when you just dump the trans pan. Change the filter, and be ready to do some cursing when you need to remove the silly little seal that seals the filter neck into the transmission. It is sort of pressed in there and you need to pry it out. Drive the new seal in with a deep socket.
