Cruisin
Tom,
I believe this has been mis-stated before. The BX2350, BX1850, BX24 NEVER had a plastic floor. The cracking problem was the fender where it extended under the steel floor. It resulted from the flexing of the steel floor when it was stepped on by the operator mounting the tractor. Kubota modified the fender in the problem area with stiffening ribs. The ribs proved to be insufficient, so a steel reinforcement for the floor was added. This reinforcement was very successful and was retrofitted and the fender was replaced under warranty, to supposedly, every BX2350, bx1850 and BX24 that suffered the crack and was returned to the dealer, even if the machine was well beyond the warranty period. There was no "Version" that you refer to.
The seat change was a Kubota good will gesture upgrade that applied to all the then current BXs as well as the older BX2230, BX1830 and BX23. I believe it also applied to several B Models. The new, more comfortable seat, was made available for a ridiculously low price of around $25. The good will period has passed and the seat now costs about $225. It was fitted to production BXs, Bs and some Ls.
Differences in the 50 series and 60 series are essentially:
Hood and fenders changed from plastic to steel. Engine side cowls remain plastic.
Priority valve changed slightly to allow a very slow movement of the loader at engine idle. 50 series required a fast idle to move the loader.
Change made in the HST to reduce the "abrupt stop" experienced in the 50 series.
Price increased.
3 point hitch made an extra cost option on the BX25.
Price increased.
