studenthousing
I have 2010 X748 all time 4WD with the 2 stage 47" snow blower. When under heavy snow load I hear a clicking or clunking sound. Although it sounds like it is up front, It is really hard to tell where the sound is from because of the cab. I do not get the sound from the 52" power broom or the borrowed 51" older power broom. I am thinking it is coming from the plastic thrower fan because there seems to be a lot of back and forth play when it is not running. The shear bolts are ok and tight, It works flawlessly otherwise. I did not think to check the play prior to the noise. I am looking for Suggestions. Possibly someone to check their blower fan for play, or to see if anyone else has had this issue. JD dealer is 2 hours away and not helpful. I don't seem to have any play in the forward shaft or gearbox. The tractor has just over 200 hours, and the PRO hydraulic fluid seems clear and no metal. I also started to notice during the last project what I would call a gear whine when any PTO attachment is operating. And the forward and reverse speeds do not seem to be as fast they were, and is nowhere close in speeds to our 2008 X748 with 1000+ hours and the 2W 4W shifter. If I posted this in the wrong area I apologize.
Thank you all in advance!
