jimmyfreeze
- Joined
- Dec 14, 2023
- Messages
- 1
- Tractor
- JD 5075E
Cold weather issue on my 2024 5075E with 60hrs. If the outside temp is approx. 20F or less, the cold start advance/noisy injector crackle "mode" will not shut off, but in warm weather it deactivates and runs normal/quiet after 5-10min which is normal compared to my previous 2018 5075E. No dtc codes, it is not a fuel or filter issue. My dealer said bring it in on dec 18th and don't expect to get it back until next year. Trying to avoid buying a $160+ manual.
Anyone know where the cold start advance sensor is located on the 2023+ 5E tractors? It's no longer on the thermostat housing like the >=2022 models. The 2023+ JD microfiche is vague, #19 shows a second coolant temp sensor, but not the location. Unplugging #13 results in key on error, no crank.
