bmryer
2210 jd will not start blows 20 amp fuse when key is in the run position must be a short where to start Thanks
I would rig up a light that you can plug into the fuse socket. If there is a short, it will light up and stay lit until you can poke around and find where it is shorting out.. be it a switch or a bad wire grounding out somewhere.
I solder a couple wires on a light socket to a blown fuse that goes into the fuse holder.
:welcome: to TBN
12 volt light, will that blow the light
