thatguy
Elite Member
I finished mowing today with the temps in the 90's.. After I let it idle while putting down the ROPS I saw a small puddle of fluid on the driveway..
Upon closer inspection it appeared to be hydraulic oil coming from someowhere in the rear end on the right hand side - high up almost just below the seat, but not from the fill tube.
I wiped the area down and it has not leaked anymore - i put a piece of paper under it, .. So Im not sure if it was just leaking when it was under pressure or not.. tomorrow I will clean it up better and let it idle to see if leaks again..
1) the sight glass is showing very full (only a small bubble at the very top) - If I had had overfilled it when I changed the fluid a month ago, is there a pressure relief valve or something that could be letting out excess fluid since it was very hot?
2) I switched from 'green grease' to a lithium-moly from Advance Auto and I noticed my grease gun had leaked a liquid out of it - which the green grease never did.. There was also some grease on the underside of the tractor from the MMM.. Could the MMM have thrown off excess grease and it melted (like it did in the gun) and leaked down?
other thoughts.. ideas?
Brian
Brian
