incubus2432
A few weeks ago I spotted a small (2") spot under where my tractor was parked. I wasn't overly concerned and figured I'd just look into it next service which is due sometime next month. Well after mowing the grass a few days ago and parking the tractor I found a spot considerably larger this morning. The whole underside just above the front driveshaft (rear side of shaft) was soaked. I sprayed everything down with brake cleaner and wiped it dry. After running it up to temperature it appears as though fluid is seeping from behind several bolt heads......I didn't have much time to further investigate today but here is a pic of the area.
Please excuse my lack of correct terminology for the parts. I am well versed mechanically for cars/trucks but this is my first tractor. It is well out of warranty and I'd rather fix it myself than pay inflated dealer prices.
So here it goes....the bolt heads in question are on the finned case thingimibob just above the front driveshaft. Bolts in question are at about the 7 and 9 o'clock position on the case itself. The oil appears to be the "hy-gard" from the hydrostatic drive. What the heck is the case and how big of a nightmare will it be to remove it and reinstall with a new gasket? I guess it's time to order up the service manual. DRATS!
