dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,188
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
Just a couple questions, what happens if you are up there and lose power?
You certainly can run the battery down going UP using that 1KW motor.
Going down, however, requires only enough juice to open the DOWN
solenoid valve: a couple of watts. So, it would be a pretty catastrophic
failure that would keep you from lowering the basket from above. I
suppose if I were worried about that, I could keep a rope in the basket...
Since I am usually on my own, I would not have a helper who could use
the redundant lower controls.
I use a couple of wing nuts to attach my power and ground leads to the
battery post connector bolts. I WOULD like to replace my battery with a
top and side connection unit, however. Attaching the leads is pretty
fast as it is.
