can you talk about the micro inverters?
I get that they generally have proprietary cabling and connections to the panels, but how does the AC side work. Do you simply use a junction box and wire nut 3/4/5 (whatever) AC leads together to join that many micro controllers all putting out 2 amps into a single 6/8/10 (whatever) amp AC lead? I assume they phase correct on there own somehow with electronics?
do you just run those AC legs back to a receptical/service panel to connect to the house/barn/shop?
is it possible to pull direct DC off the microinverters for battery charging or DC lighting? can you use a backup battery bank and microinveters together?
